It is currently Wed Nov 04, 2026 8:52 pm
Vehicle: 91 WT 1.6EFI
Post Posted: Sun Mar 06, 2011 2:40 am
Does any one know who many times its safe to splice the accessory wire? mines been done for cd player, uhf, under dash lights, cigarette lighter, and 2 switches for spotties. Thats 6 all up 8O . if I replace the original wire with high gauge will this help keep my wiring harness from lighting on fire? thanks
Post Posted: Sun Mar 06, 2011 3:46 am
Why are the switches for the spotties wired off the acc wire? The spots should be getting power directly from the battery to the relay. The acc wire probably only has a 15amp fuse. I'd say you're pretty close to that without the spot lights added in
Vehicle: '94 suzuki maruti
Post Posted: Sun Mar 06, 2011 5:22 am
im pretty sure just the switches are getting the power from the acc wire, not the actual spotties. at least, thats how i read it...
Post Posted: Sun Mar 06, 2011 8:28 am
What do the switches need power for?
Vehicle: Vitara
Post Posted: Sun Mar 06, 2011 8:30 am
I'm guessing they have an LED in them?
is there more then 1 accessories wire? I have similare items except the spottie, just dont want to start blowing fuses..
Ron
Repping it, High Top style!
Post Posted: Sun Mar 06, 2011 8:38 am
Still don't need a separate acc power run to them.
Vehicle: '96 LWB trayback
Post Posted: Sun Mar 06, 2011 8:42 am
Spotties are using switched power for the relay trigger I'm assuming?
I run mine the same way.
Acc to switch to trigger the relay. Low current side.
The acc switch system in the sierra ignition barrel is pretty piss poor. I would use it to trigger a relay and run all your accesories of that. Much better idea!
Dan
Lil Foot!
Post Posted: Sun Mar 06, 2011 8:51 am
What is the acc wire switching on the relay? The switch should be cutting the highbeam trigger wire.
Vehicle: LWB Sierra & XL7
Post Posted: Sun Mar 06, 2011 9:05 am
You'd be able to run a dedicated 8 guage accessory wire from the alternator, feed it into a fused distribution block and run what you like off it. I think it would be a bit safer than overloading one wire.
Here's the result of just a quick search to give you some ideas..
http://www.auszookers.com/index.php?nam ... ht=fusebox
http://auszookers.com/index.php?name=Fo ... +aux+power
Post Posted: Mon Mar 07, 2011 2:07 am
jr jook is correct the acc is just to turn the spotties on. the power to them is from the battery, and they are not wired into the high beams.
Thanks for the ideas, I'm going to turn everything on and see if it blows a fuse. if it doesn't I might just leave it at this point because I have nothing else to add on and I won't ever use everything at the same time.
Post Posted: Mon Mar 07, 2011 2:12 am
I dont see 5 amps in everything youve listed there, plus whatever you plug into the lighter socket
I wouldnt worry about it
Users browsing this forum: Google [Bot] and 177 guests
