It is currently Wed Nov 04, 2026 8:00 pm
Post Posted: Fri Mar 11, 2011 9:56 pm
Suzuki Sierra, 2" Lovells spring lift.
The hole on the spring perch is about 10mm back from the pin on the spring. The shackle is also all the way to the stop.
How the f#%^ do I get them to line up?
Post Posted: Fri Mar 11, 2011 10:03 pm
what? I read that 5 times.. A pic mite explain it better
Post Posted: Fri Mar 11, 2011 10:08 pm
the rear end im guessing?? are they definately rears?
Post Posted: Fri Mar 11, 2011 10:13 pm
yeah driver rear at the moment. they are definitely rears. and it has "D/S" on it so i know its the right one. just isnt being cooperative...
uploading pictures now.
Post Posted: Fri Mar 11, 2011 10:16 pm
Post Posted: Fri Mar 11, 2011 10:31 pm
unbolt it from the shackle...
allign diff into pin
then jack that side of the diff up and put the shackle back through..
Post Posted: Fri Mar 11, 2011 10:44 pm
have you un done the passenger side u bolts
josh AKA Bazook
Post Posted: Fri Mar 11, 2011 10:47 pm
How do I then get the shackle back on?
I haven't no. Doing one corner at a time.
Post Posted: Fri Mar 11, 2011 10:52 pm
Just undid the shackle. Same situation. Just no it's no attached at the shackle end.
Post Posted: Fri Mar 11, 2011 11:04 pm
Move the diff. I put or tried to put in camber wedges, wrong size holes, when I went to set it back as it was, same problem your having.
Undo both spring hangers, move the diff to align the holes, then do the hangers, you may have to use force to get the hangers back on, I did, no biggy really.
When doing one side only, everything is held in position by the other side, undoing both sides makes it a piece of cake.
Vehicle: Daisy
Post Posted: Fri Mar 11, 2011 11:09 pm
I haven't done it but mine has the diff moved back, make sure you check clearances for your shocks e.t.c once you've moved it.
Vehicle: LJ20 LJ50
Post Posted: Fri Mar 11, 2011 11:15 pm
Put jack stands under chassis and let the diff droop. Undo everything and then bolt in springs. THEN do up U bolts loosly and align diff. Then fully clamp down and hold diff down. You can't expect lifted springs to be exactly the same as standard springs can you.
This is a good learning curve for you. Helps understand the way springs work.
If you undo the u bolts on both sides it will be so easy you will beat your self for not doing it earlier
Camels have nice toes
Post Posted: Fri Mar 11, 2011 11:20 pm
I've changed heaps of springs one at a time..(My car has quite an appetite for them)
Jack up the spring until the diff is supported by it and then kick the diff into place. Sounds rough but works and saves a lot of time....
In your case if you are changing both rear springs loosen the Ubolts on the other side and you should be able to align the locating pin fairly easily.
Post Posted: Fri Mar 11, 2011 11:29 pm
x2 jack the the springs up. i only just did mine in the rear and it worked for my first time on changing the springs.
matt
Post Posted: Fri Mar 11, 2011 11:46 pm
I undid the p/s ubolts moved the diff. Cheers guys.
Now my shackle won't go in. Will the angle return when the springs get some weight on it and settle in?
Post Posted: Fri Mar 11, 2011 11:59 pm
Ah so you only undid half of it....
Yes the shackle will return..Depending on how stiff the springs are.
Post Posted: Sat Mar 12, 2011 1:51 am
Thanks guys. It's all going well now :D
Rear is up! Having a break then doing the front WITH AIR TOOLS! (I'm buggered)
Post Posted: Sat Mar 12, 2011 3:04 am
my quick way of doing 2 springs
jack up, stands under chassis, let suspension drop
undo all ubolts, lift diff clear slightly and hold with more stands
undo and remove shackle, let spring drop, same for other side
remove pin other end, chuck old spring and slip new one in and do up loosley, same for other side
lift up spring and put shackle back in, do up loosly
drop diff onto springs, slide into locating holes and put plates and u bolts in
lower back to ground and do pins and shackles up
never need any effort to get anything to line up that way
Users browsing this forum: Google [Bot] and 181 guests
