It is currently Sun Nov 08, 2026 2:51 am
Vehicle: LWB Sierra
Post Posted: Wed Apr 06, 2011 6:40 am
Hi All,
I have blown my rear diff a few weeks ago and having troubles pulling out the axle.
The things I have tried:
* Hitting the axle with a hammer and let vibrations work its magic to wiggle it out
* Putting timber on the back of the drum backing plate and hitting it with a hammer
* Undoing the diff centre bolts and wiggled that around to loosen it from the axle
* Sheer brute force
* Putting the drum brake on backwards and again use brute force
* Some more sheer brute force
I know I haven't really tried that many methods but it just seems to be permanetly stuck.
Someone else has suggested I bolt my tyre back and and wack it with a sledge hammer but I think the car is going to come off the stands if I attempt to.
Are there any other methods that have worked for people here? the zook looks so lonely in the garage on stands.
I can also offer tinnies or some cash for someone who is up for helping me get this out :)
Post Posted: Wed Apr 06, 2011 7:01 am
hey man i had some prob i ended up putting tyre on and wacking it but just make sure that ur car is secure and wont fall ontop of u .. also make sure the center is bolted up and just take a huge back end of axe or sledge poped of 2nd hit.. but in saying that i could not swing hard enuf to do it a mate manged to do it ..
Post Posted: Wed Apr 06, 2011 7:56 am
I got hold of a slide hammer and welded on a wheel nut, wind the nut onto the axle stud and tap it off, so much more easy (and safe) than brute force.
Post Posted: Wed Apr 06, 2011 8:25 am
you could manufacture a dodgy slide hammer with a length of chain and a besser block if you get my drift
Post Posted: Wed Apr 06, 2011 8:36 am
The way zooks used in mud with bigger than stock tyres go through wheel bearings I thought a proper slide hammer was worth it, especially with the number of Zooks at my place.
Post Posted: Wed Apr 06, 2011 8:39 am
this may be a stupid question, but... did you undo the backing plate?
If you don't get stuck you aint tryin' hard enough
Post Posted: Wed Apr 06, 2011 8:41 am
:lol: I thought that, but wanted to give hm the benefit of the doubt..
Vehicle: LWB Sierra
Post Posted: Wed Apr 06, 2011 8:52 am
I get your drift and hopefully i can make something out - i cant really see the difference in hammering the back and making a dodgey slide hammer.
Post Posted: Wed Apr 06, 2011 8:53 am
:oops: :oops: I did that the first time I went to take out rear axles :roll:
Vehicle: LWB Sierra
Post Posted: Wed Apr 06, 2011 10:01 am
haha yes i did undo the backing plate guys.
how much do you think a diff specialist will smash this out for?
Vehicle: LWB Sierra
Post Posted: Fri Apr 22, 2011 1:06 am
ok guys i have procrstinated a little too much and the old man has cracked the sads from the zook being in the garage for a bit.
i've tried to slide hammer technique and there is still not luck,
can someone please let me know if i will damage my tyre if i wack it with a sledge hammer? If i hit the rim it will put it out of balance right?
thanks!
Vehicle: Daisy
Post Posted: Fri Apr 22, 2011 1:29 am
Do the old chain or rope trick as suggested, put a chain or rope around something heavy (or the end of your sledge) other end around the part you're trying to remove, and swing away jack!
Post Posted: Fri Apr 22, 2011 1:32 am
thanks!
Don't hit you rim. Unless you want to buy another :wink:
Post Posted: Fri Apr 22, 2011 1:41 am
http://www.auszookers.com/index.php?nam ... ic&t=19477
Vehicle: LWB Sierra
Post Posted: Fri Apr 22, 2011 1:47 am
royce that is awesome! thanks i'm going to give it a crack now.
easter long weekend trying to fix a car is no fun... i should be out there!
Post Posted: Fri Apr 22, 2011 4:40 am
I used a much heavier chain, and no sledge, it worked ok.
One we had was no way, not coming out. I learned that if you heat the bearing cup, and heat it real good with a propane torch (not an oxy-ace) that they will come out with one blow from the chain.
Give some heat (and plenty of it too.) on the bearing cup a try right before you try your new chain/sledge combo. think you will be surprised.
Post Posted: Mon Apr 25, 2011 4:58 am
the chain technique was the only way i even got mine out, we used a wood splitter on the end of the chain lol
Post Posted: Mon Apr 25, 2011 5:05 am
We actually used two trucks to get on out, it was bad. My neighbors must have loved me.
We had one 88-ish full size Chevy tied to the axle to come out, and my full size 94 long bed Chevy filled with scrap metal in the driveway, chained to the housing.
We tried pulling gentle and it did not work, so we hit it hard. it took about 6 or seven blows and drug my truck 3 feet sideways before it popped.
My rig was sunk in the water, and the diff oil was not change while it sat for a year lol.
Did I mention the neighbors hate me? lol.. they learned not to make me upset or comment about me working during the daylight hours though. The raw power of an un-muffled 1.6 sounds awful good in the early AM on Sundays. (almost as good as a grinder on a thin piece of tin) armsup armsup
Post Posted: Mon Apr 25, 2011 5:06 am
I smashed a CW & P just before christmas and tried all the chain/brake drum/sledgehammer/ etc tricks to remove the LH axle and none worked... :evil:
I ended up going to Glenfords and buying a slide hammer... :twisted: $190
Worked a treat and makes any future axle pulling so much easier... :D
Vehicle: LWB Sierra
Post Posted: Tue Apr 26, 2011 12:19 pm
I actually used the link Royce gave me. Used a thick chain and a massive sledge hammer. After about 10 minutes of trying I spat the dummy and kicked the rock slider. Hurt my foot and got even more worked up and tried one more time. Popped out and landed on that same foot.
Think my car is possesed at the moment. Will post up a photo of the diff centre sometime soon. Thanks all for your help
Post Posted: Tue Apr 26, 2011 1:09 pm
i had to get an axle out of my spare Lj diff, was stuck in good and proper, wasnt in need of the axle or anything, so i gave it to swift hits on the backing plate,
with FBH and it came out easily,
couldn get it out any other way tho
dodgy brothers mechanical
Users browsing this forum: No registered users and 127 guests
