| Author |
Message |
SierraDan
Joined: Fri Feb 04, 2011 10:55 pm Posts: 9348 Location: Newcastle
 Posted: Thu Apr 14, 2011 8:58 am |
Ive got this adaptor that goes in line with the cooling system (hoses) to give a reading to my temp gauge.
Where would the best spot be for an accurate temp?
There's a good straight spot in between the bottom hose and the motor that would make it easy and reliable to fit, would that be a good option?
_________________ mlm
zooky08
Joined: Fri Nov 27, 2009 10:30 pm Posts: 3426 Location: imbil/gympie. qld
 Posted: Thu Apr 14, 2011 9:01 am |
the hose from top tank to thermostat
_________________ 03 Jimny 30 km2s 75mm lift f&r locked winch
SierraDan
 Posted: Thu Apr 14, 2011 9:04 am |
hmm.. may have to find another hose that wont have kinks in it then.
zooky08
 Posted: Thu Apr 14, 2011 9:12 am |
i could be wrong
i would just wait until some one else post to make sure
SierraDan
 Posted: Thu Apr 14, 2011 9:16 am |
im not doing it till Saturday anyway, so ive got time
cheers
abclarke
Joined: Mon Feb 14, 2011 8:19 am Posts: 1966 Location: Couridjah
Vehicle: 1985 Holden Drover
 Posted: Thu Apr 14, 2011 9:32 am |
I might need one of those seeing as my temp guage does sweet fa
_________________ 1989 WT Sierra.
xedent
Joined: Mon Jun 15, 2009 11:30 pm Posts: 895 Location: Sunshine Coast, QLD
 Posted: Thu Apr 14, 2011 9:51 am |
It will only tell you the temperature of the water as it leaves the motor (when the thermostat opens) so if the thermostat seizes shut your motor could be cooking and you wont know, best to just replace the original temp sender with the one from the gauge you bought.
_________________ My Maruti build, Click WWW
whincup
Joined: Sat Apr 17, 2010 11:30 pm Posts: 1588 Location: Gracemere, QLD
Vehicle: '94 suzuki maruti
 Posted: Thu Apr 14, 2011 9:53 am |
zooky08 wrote: the hose from top tank to thermostat
this is the most reliable spot, as it will give you the temperature of the water coming straight from the engine. if its in the bottom hose, thats the water thats already been cooled by the radiator... as for the kinks, dont just cut the hose in half, cut about 2 inches of the hose out of the middle...
SierraDan
 Posted: Thu Apr 14, 2011 10:13 am |
whincup wrote: dont just cut the hose in half, cut about 2 inches of the hose out of the middle...
Nah, wasnt planning on it. Was going to cut out the size of the centre block. It just seems like it will interfere with the bends.
whincup
 Posted: Thu Apr 14, 2011 10:36 am |
i havent got one myself yet, so i dont know for sure if it will, but yeah i imagine it probably would...
Taylor74
Joined: Fri Dec 24, 2010 10:26 am Posts: 198 Location: Perth WA
 Posted: Thu Apr 14, 2011 11:22 am |
Dont waist your time on it. as xedent said if the thermistat jams shut your none the wiser. It might be cheap and that would be for a reason. why would anyone risk there engine to a 3rd party excuse of a gauge. rely on the factory made in japan thing, if its not reading correct fix it be much better than that after thought of a sender
_________________ Suzuki is my way of life.
cairns27
Joined: Thu Dec 23, 2010 7:42 pm Posts: 489 Location: Macleay Island
 Posted: Sat Apr 16, 2011 9:08 am |
I'm on taylor74's side. I drive by my tempreture guage. It is the only thing I worry about till I'm home.
bye
TheOtherLeft
Joined: Sun Aug 27, 2006 11:30 pm Posts: 818 Location: Sydney
 Posted: Sat Apr 16, 2011 12:16 pm |
What about an engine block temp gauge instead? I figure if you lose all of your water your water temp won't get a reading whereas the engine temp will skyrocket.
_________________ 2002 SWB GV
Lifted and Locked
xedent
 Posted: Sat Apr 16, 2011 9:35 pm |
Or you can just replace the engine temp sender with the one given to you with the gauge you bought.
fordem
Joined: Mon Apr 19, 2010 11:30 pm Posts: 2656 Location: Georgetown, Guyana
 Posted: Sat Apr 16, 2011 11:29 pm |
xedent wrote: Or you can just replace the engine temp sender with the one given to you with the gauge you bought.
Ahhh - every aftermarket gauge sender I've had was waay larger than the OEM temp sender - except my old BMC A series 850 - that didn't have a temperature gauge from the factory, so there was no sender.
jonno_racing
Joined: Wed Apr 15, 2009 11:30 pm Posts: 8164 Location: Tassie
 Posted: Sat Apr 16, 2011 11:44 pm |
gti has 2 spots, one in the back of the head (where mine is) and one in the thermistat housing (where my factory gauge runs) is there more than one spot?
_________________ Do cool stuff, Put it on the internet Sierra build, Jimny build https://www.youtube.com/user/redzook1
mondo
Joined: Wed Dec 29, 2010 10:18 pm Posts: 481 Location: Jimboomba
 Posted: Thu Apr 21, 2011 11:16 am |
hey SIERRADAN, i've got a mate who needs something similiar to what you have pictured, where did you get this from?
SierraDan
 Posted: Thu Apr 21, 2011 11:30 am |
Super cheap!
mondo
 Posted: Thu Apr 21, 2011 11:33 am |
cairns27
 Posted: Mon Apr 25, 2011 5:43 pm |
If ya temp guage is not reading, it may be that the themostat has been removed.
I tried new sender, cluster, then took radiator cap off and started motor, no f'n thermostat.
Takes a full day, you'll need a spare car with a full tank of fuel.
Easy to do really.
Remove top raditor hose.
Break heads off bolts holding housing then get big screw driver and lever housing off. Use vice grips to remove the stud closest to the raditor, then break stud near carby off level with surface of manifold.
Drill and and stop using ezi-out just before it breaks.
Then remove those diapham thingys from side of carby, and drill and tap.
Replace everything using new bolts that will have 13mm heads.
You will need to drive back and forth to Coventry 4 times for new tools, as ya won't know the quality of the loose ezi-outs and taps ya have laying around.
bye
cairns27
 Posted: Mon Apr 25, 2011 5:45 pm |
Easy to do really.
bye
