It is currently Mon Aug 03, 2026 1:01 am
Vehicle: 91 WT 1.6EFI
Post Posted: Sat Apr 16, 2011 2:01 am
ok so I'm doing the clicky starter fix and its just not working for me.
I bought a 40/30amp relay
I pulled apart some jumper leads for the wire from the battery to the relay and the relay to the solenoid.
I am using 16 guage speaker wire (what I use to run my spotties) for the relay to battery earth.
I have the battery to relay hooked up to power in in the relay
trigger wire is hooked up to the switch terminal
ground is on the ground
and relay to solenoid wire is on acc out 1 (there are 2.... 5 pin relay)
I have tried swapping some of the wires around but I am still getting nothing.
Post Posted: Sat Apr 16, 2011 2:16 am
is the relay clicking when ya try to start it?
Post Posted: Sat Apr 16, 2011 2:17 am
I believe so, I'll go have a look
Post Posted: Sat Apr 16, 2011 2:19 am
nope, it was clicking with different wire configuration though
Post Posted: Sat Apr 16, 2011 2:21 am
wait, yes it is, I wasn't turning the key far enough. oops
Post Posted: Sat Apr 16, 2011 2:27 am
Do you still have a big cable direct from battery to starter?
Post Posted: Sat Apr 16, 2011 2:31 am
yup
Post Posted: Sat Apr 16, 2011 2:38 am
Relay wiring should be:
Pin 30- battery feed (fused close to battery)
Pin 85- trigger feed
Pin 86- earth
Pin 87- output to solenoid
Does your relay have 87 & 87a or just two 87's?
Post Posted: Sat Apr 16, 2011 2:43 am
its 87 and 87a and I don't have a fuse in the battery feed. I can put one in but the car has to run so I can get to the shops.
ok I have set it up like you said... the relay clicks when I turn the key but no start
Post Posted: Sat Apr 16, 2011 2:45 am
Get someone to hold the key on while you tap the solenoid with a hammer
Post Posted: Sat Apr 16, 2011 2:53 am
started right up!!! cheers mate! should I still get a fuse for the battery line? I can head over to super cheap right now
Post Posted: Sat Apr 16, 2011 2:58 am
That battery wire MUST be fused! You have a sticky solenoid on your starter too
Post Posted: Sat Apr 16, 2011 3:04 am
ok, should I have a look out for a new solenoid? I know a couple posts on here said you can pull them off a lancer
Post Posted: Sat Apr 16, 2011 3:10 am
what size fuse do I need to get, I'm assuming it needs to be something quite large
Post Posted: Sat Apr 16, 2011 3:16 am
15A will be fine. It doesn't draw that much through the trigger circuit
Not sure on solenoids
Post Posted: Sat Apr 16, 2011 3:30 am
righto thanks so much for your help Scrawn
Post Posted: Sat Apr 16, 2011 3:38 am
if you were in WA you could have the 1.3 starter i have here... looks brand new.
Vehicle: 2018 DMAX
Post Posted: Sat Apr 16, 2011 3:45 am
Rossco, i picked up a spare solenoid the other day from the wreckers you can have if you want.. Just send me a pm
Post Posted: Sat Jul 23, 2011 8:18 am
Can solenoids be cleaned?
Post Posted: Sat Jul 23, 2011 8:28 am
i have never tried a suzuki starter but landcruser starters can.
Post Posted: Sat Jul 23, 2011 8:31 am
Mine takes about 20 key flicks for it to do anything :roll:
Post Posted: Sat Jul 23, 2011 8:34 am
yeah they can be. I searched for this same thread earlier today :lol: clicky fix is great :D
Post Posted: Sat Jul 23, 2011 8:43 am
Should be able to strip and clean the solenoid.
Users browsing this forum: No registered users and 208 guests
