It is currently Sat Aug 01, 2026 7:37 am
Post new topic Reply to topic  [ 88 posts ]  Go to page Previous  1, 2, 3
Post Posted: Sun Apr 17, 2011 7:50 am
steak_knife wrote:
nah not the barrel, just the immobilser, on a liana it bolts to and sits around the barrel, I reckon it would fit over a sierra barrel
plenty of other hurdles though, things like the vss being in teh gearbox :)
I used a relay & a flasher unit to trick the 4age comp into thinking it was doing around 5kph :D
did the constant ticking get annoying :)
you could give it a signal easy enough through the usual speedo vss but are they getting to be smart enough now to know what sort of revs they will see compared to speed for each gear? if its too far out it might upset it?
Vehicle: Daisy
Post Posted: Sun Apr 17, 2011 8:15 am
VSS is speedo sensor?
I haven't worked on an engine with computer control before!
Also, aren't we also talking about using the M gearbox with the M motor? or is that too hard also?
Post Posted: Sun Apr 17, 2011 8:17 am
the only m gearbox in rwd is the jimny one, its probably going to explode with a bigger engine
Post Posted: Sun Apr 17, 2011 8:18 am
VSS= Vehicle Speed Sensor.
The M box is like the G16 vit box, where by it uses a remote shifter. This puts the gearstick where the transfer case hole is......
Vehicle: Daisy
Post Posted: Sun Apr 17, 2011 8:24 am
^ and ^^
Bugger and Bugger.
What about some kind of conversion from a standard sierra transfer drive into the electronic pulse it's looking for? I know we're getting back into complicated again but it's just an idea.
Post Posted: Sun Apr 17, 2011 8:25 am
Well Before dissmissing the Mseries box, I'd look at removing the remote shifter and adapting a sierra 5sp shifter neck. Bothe Tanshi and I have done this to G16 boxes, and it works very well.
Vehicle: Daisy
Post Posted: Sun Apr 17, 2011 8:31 am
Weren't we dismissing the M box due to the extra power of the M15 over the M13?
I'm going to google to find out the figures!
Post Posted: Sun Apr 17, 2011 8:32 am
makes sense. They aren't renowned for their strength. Although there is someone on this board with a turbo M18 infront of one...?????
Vehicle: Daisy
Post Posted: Sun Apr 17, 2011 8:36 am
Holy moley!
So the other obvious question is would there be a way to mate it to a G series box? or something else that would suffice?
Post Posted: Sun Apr 17, 2011 8:37 am
Just an adaptor I would imagine. I reckon a vit box would be all you would ever need. But some slight tunnel mods and a new crossmember would be required.
Post Posted: Sun Apr 17, 2011 8:40 am
yeah i'd like to see a v6 box behind one I think
cant remember his name has an M15 in a sierra (go to rigs now its up the top) and he modded sierra box parts to make it work
Post Posted: Sun Apr 17, 2011 8:51 am
Some site owner you are :roll:
Post Posted: Sun Apr 17, 2011 8:53 am
dont you have an avatar car to go finish, see we already sorted out your key problems
Post Posted: Sun Apr 17, 2011 8:54 am
G16b....what key problems :roll:
Post Posted: Sun Apr 17, 2011 8:56 am
:lol: It ha A 4age in it, I couldn't hear a fucking thing!!!
well sort the rest out then :)
Post Posted: Sun Apr 17, 2011 8:59 am
Just pretend I'm Bruce and come and do all the work for me :finger:
Post Posted: Mon Apr 18, 2011 12:34 pm
Type 2 jimny M box is the easiest to use. Swap the sierra selecta shafts into it, get a sierra rear housing, Trim a tad off the countershaft and poss machine the housing a tad and you have a M series sierra box that bolts straight in. Why would anyone want to do anything else when its that simple
Suzuki is my way of life.
Post Posted: Mon Apr 18, 2011 12:55 pm
wouldn't an adapter plate be easier?
Post Posted: Mon Apr 18, 2011 1:09 pm
M sieries flywheel is too big to fit a sierra gearbox and as you know the sierra bellhousing is part of the gearbox. The sierra flywheel wont fit the M sieries engine either too small to allow the starter to fit to it, plus different bolt pattern
Post Posted: Mon Apr 18, 2011 1:18 pm
G16 box would fit :wink: And you could easily plug an M18 in front of it :wink:
Post Posted: Thu Apr 28, 2011 9:13 am
Has anyone had thought on what the grandvits, m16a box's are? Same as Jimny?
Post Posted: Thu Apr 28, 2011 9:27 am
GV's came out with an M16? 8O 8O
Vehicle: Daisy
Post Posted: Thu Apr 28, 2011 9:37 am
We got any progress on a conversion with one of these?
Post Posted: Thu Apr 28, 2011 10:08 am
All the 2door GV's are oddballs! Like the 1st of the gv'shape 2door with a g16b. :lol: , yet the previous model had the J20..wtf..
Abit like how every small model suzuki runs a m series, then the sx4 jumps out with another j20..
So the Gv has m16, j20? j24 H27 and the terrible pug1.9
M16a I wonder if these models were the ones without lowrange?
e.g. http://www.carsales.com.au/Tig/UI/PageP ... allcarhome
Post Posted: Thu Apr 28, 2011 11:00 am
Wheres the Steak Knife?
I asked him about this once, I think he said the bell housing is 14 mile long or something... Was definitely something I recall him saying made it prohibitive... (aside from the fact that maybe 3 were ever sold in Australia.... :lol: )
Clearance Hole Technology :P
Post Posted: Thu Apr 28, 2011 11:04 am
:helloo:
Shit, the gv3 has a stupidly long bell housing & concentric slave..
Not worth looking at..
Vehicle: Daisy
Post Posted: Sat Apr 30, 2011 9:04 am
Ok so to bring this thread up again.
Am I understanding properly, that the bloke doing the M18a into a Jimny in the rigs section, is getting around the problems we're talking about in this thread (with immobiliser shenanigans and gearbox vss issues) by using an after market ECU?
Which is not the point of this thread because we are looking for a conversion that becomes drop in without needing dyno tuning?
Users browsing this forum: Google [Bot] and 66 guests
