It is currently Mon Oct 19, 2026 10:03 am
Post Posted: Tue Aug 12, 2008 9:08 pm
Has anyone had jackaroo rear springs in there suzuki?
because i got some i will go look at them tomorrow
Post Posted: Wed Aug 13, 2008 8:10 am
Width? Length? # of leaves? Thickness of leaves? Centre pin location?
Post Posted: Wed Aug 13, 2008 9:52 am
Greg on this board aka 1madengineer had them in his old Sierra I think. Hopefully he chimes in and says something.
Post Posted: Wed Aug 13, 2008 10:45 am
jeez you have a good memory!
i had isuzu ute rears. they are 50mm wide like sierra but the ctr pin is 1.5" back and they are ~120mm longer. which is ideal for a zook. they are about a 3-4" lift. I am trying to remember, it has only been 6 year :cry:
Post Posted: Wed Aug 13, 2008 3:28 pm
what isuzu ute, the rodeo? sound better than hilux witch is what i was going to use
Post Posted: Wed Aug 13, 2008 3:34 pm
hilux are way to big isit isuzu ,rodeo, jackaroo the same
hello
Post Posted: Wed Aug 13, 2008 3:45 pm
hilux fit but are tight, they are 60mm wide and about 1150mm long with the pin sitting the diff about 25mm back in the rear.
Post Posted: Wed Aug 13, 2008 4:08 pm
i had a lux spring just sitting in my front and goes past the front bumper
hello
Post Posted: Wed Aug 13, 2008 5:02 pm
thats becuuse front springs are shorter than rears, thats why people do ruf and hilux in the rear.
Post Posted: Wed Aug 13, 2008 5:27 pm
Is the extra 1.5" enough to cause problems with tyre clearance against the tank?
92 WT softback ute, twin lockrights, 3.9 diffs, S1
Post Posted: Wed Aug 13, 2008 7:25 pm
bash it with a hammer if it gets in the road
hello
Post Posted: Wed Aug 13, 2008 7:57 pm
bash the fuel tank with a hammer????? yeah real smart
Post Posted: Wed Aug 13, 2008 8:00 pm
My tank has already lost enough capacity from dents, i won't be able to make it between servos if i lose any more :p
I spose i could just redrill the perch to move it 15 or 20mm forward again.
Post Posted: Wed Aug 13, 2008 8:04 pm
or cut the floor and send it up into the back
Post Posted: Wed Aug 13, 2008 8:45 pm
what about jackaroo springs front and rear or jack in rear and ruf will that work good
hello
Post Posted: Wed Aug 13, 2008 8:59 pm
if you put rear jackaroo springs in the front you would need some lifted jackaroo springs for the back.... it would be very difficult to set up right aswell
Post Posted: Wed Aug 13, 2008 11:02 pm
what about if i was to put jackaroo ones front could i pull out somd leafs in the front and maybesome in the rear becauseif you put them in its like a 4 inch lift by pulling out leafs you get it lower and more flex.
hello
Post Posted: Thu Aug 14, 2008 6:51 am
They would be about 200mm longer than the standard fronts, the only way to fit them in would be to extend the chassis.
Post Posted: Thu Aug 14, 2008 6:28 pm
and pulling out leafs wouldnt drop the car much but would give more flex
Post Posted: Thu Aug 14, 2008 6:32 pm
no it wont thats 100% ass about
less leaves = lower spring rate so more sag for same amount of free arch so it will sit lower
amount of leaves will make bugger all difference to amount of flex unless they are so stiff that you get no uptravel
Post Posted: Thu Aug 14, 2008 6:45 pm
unless he runs it on 2 leaves there is still going to be like 3" lift possibly more
Post Posted: Thu Aug 14, 2008 7:16 pm
do you know what the spring rate will be with 2 leaves?
do you know what the free arch of the springs will be with 2 leaves?
do you know how much weight there will be supported by the springs?
do you know what shackle angle and length he will be running
no?
then how will you have any idea what height it will be?
leaf springs have a shitload of maths involved to know whats going to happen before you put it together, making a few assumptions on an internet forum about what a random combination WILL do is how people end up thinking something is the be all and end all of a mod, like drilling the mount back 25mm for RUF and commodore wagon shocks are the be all and end all of suzuki suspension, when in reality I did that like 5 years ago cause my 31's were fouling the bullbar, the shocks I had were too short, it was a hot saturday, I was hung over and wanted to go home
nows its some half baked folklore
Post Posted: Thu Aug 14, 2008 7:20 pm
but it works and is cheap, :) lucky you had the hangover
Post Posted: Thu Aug 14, 2008 7:35 pm
no?
but, but, i read it on the innernet...!
:thefinger:
Users browsing this forum: Google [Bot] and 384 guests
