It is currently Sat Aug 01, 2026 6:43 pm
Post new topic Reply to topic  [ 68 posts ]  Go to page Previous  1, 2, 3  Next
Post Posted: Tue Apr 19, 2011 2:17 am
tanshi wrote:
I can tell you with a locker in the front that you cannot turn off your line choice and the ability to actually get the car on the line will be 1000x worse than some one who drives unlocked or can unlock their locker.
I 100% agree with you there... it's a mission.
Post Posted: Tue Apr 19, 2011 2:20 am
tanshi wrote:
where is the talent and driving style gone when every thing is point and shoot?
Thats what I love, but, as I go out by myself 99.9% of the time, if I fuk up and am hung up, it would be really nice to bung her into 4wd, flick a switch, drive a few feet, flick the switch again, out of 4wd and away. A lot of the time I can lift her off, but im gettin old and sore, so, front and rears will be going in when the build finally gets under way.
Vehicle: 1989 Vitara SWB
Post Posted: Tue Apr 19, 2011 2:21 am
Thanks for all you help everyone and sorry about posting it in the wrong section
New to fwd's and forums lol once again cheers for all of your help
Post Posted: Tue Apr 19, 2011 2:22 am
X1000 worsers again if its a low traction surface :wink:
Lil Foot!
Post Posted: Tue Apr 19, 2011 2:23 am
I totally agree, I dont have lockers in my off road car, but only because i cannot get arbs for the LJ
My sierra has twin airs, as doesn my neighbours, but they are generally used only as a recovery aid.
Post Posted: Tue Apr 19, 2011 2:26 am
Recovery aid, thats the name. Thats all they are for IMO.
Vehicle: 93 Sierra
Post Posted: Tue Apr 19, 2011 3:01 am
I have auto lockers front and rear, mainly because my Zook is just a play toy these days. I would *love* to have ARBs both ends but just couldn't get approval from the Minister of War and Finance.
I agree with most of the posts on both sides of the fence here. Auto's have their negatives, but are a big improvement on having nothing too. Offroad I tend to run with passenger side locked in and driver's side out, and typically run around in 2WD Low. That way I'm doing most stuff in rear wheel drive (keeps a good challenge) but have 3WD available via the transfer, with no detraction to turning performance. If I get stuck and need full 4WD then it's just a matter of locking in the driver's hub.
Not perfect but works pretty well. i'm happy with the result for the price. Would never do it on a DD though - air all the way.
*edit: I don't agree that they're "rotten" or "horrible" - they are just a cheaper solution that has limitations. If you can accept the limitations and aren't driving it daily, then I think auto's are a valid choice.
Post Posted: Tue Apr 19, 2011 3:50 am
2 things.
Will this locker fit in the rear jimny diff http://www.lowrangeoffroad.com/index.ph ... ckers.html (the $209 one)?
Other thing, if i had the coin for a air leaker i would buy them, but at this stage i don't :) , but for now i want more traction and it is the cheapest form of gaining traction for me.
Post Posted: Tue Apr 19, 2011 4:13 am
It would be nice if these were made for Suzis, they look the goods.
Vehicle: 2018 DMAX
Post Posted: Tue Apr 19, 2011 4:42 am
TryHard wrote:
This afaik is the result of the locker... My rear had issues disengaging and caused all sorts of issues driving.. The bolts were well and truly done up and coverd in loctite. Then this happend.
umm id doesnt look like u have any lock tight on those threds .. they are ment to have it .. mine do.... maby thats why yours came lose ..[/quote]
Id bet my left nut there was loctite.. as I put it together. Maybe the fact it was spinning around in oil at a fairly rapid rate the loctite is no longer visible. :helloo:
Post Posted: Tue Apr 19, 2011 8:07 am
I might be talentless but mine holds a line(even with 2 autolockers) that's how Col got it straight up the Rutted Hill. But seriously this must be locker debate number 9999. If they were the same price there's no comparison and if air was available for mine I'd probably go air and spend the coin. At the end of the day they both get you the same place, just air is better to live with. Really though only the front one is at all noticeable and is a bitch if I attempt to go "fast" in high 4.
Post Posted: Tue Apr 19, 2011 8:29 am
Id bet my left nut there was loctite.. as I put it together. Maybe the fact it was spinning around in oil at a fairly rapid rate the loctite is no longer visible. :helloo:[/quote]
Guess that explains the noises.
Post Posted: Tue Apr 19, 2011 8:33 am
:lol: Nope, case that was before the noise's.... 8O
Post Posted: Tue Apr 19, 2011 8:46 am
That would have sounded AWESOME like a US air raid!
Sorry to hi-jack this thread.
But can anyone confirm the 1510# lock wrong will fit in the jimny rear diff?
Vehicle: 2018 DMAX
Post Posted: Tue Apr 19, 2011 8:48 am
Worked out what was causing the issues when i pulled it out, two of the pins were catching and not letting it unlock untill it had a motherload of force on it, i couldn't compress the two parts by hand... Sparten must not have very tight tolerances in there parts 8O . My front one works sweet.
I reckon the locker been so violent contributed to those bloody bolts comeing undone..
Vehicle: 2004 SQ625 GV
Post Posted: Tue Apr 19, 2011 8:49 am
I have a lockrite. Only issue is the twisted spline but air lockers do that too, mugui snapped his axle with an ARB locker.
The ratcheting isn't hard on the parts. Mine free wheels gently and i can hardly hear it let alone feel it. it's when the locker jumps a tooth under load is when there is an issue and shock loads the system.
Alot of guys in sierras on here don't like them but I think it is a weight and size issue of the car.
Detroits would have to one of the nicer autolockers. I have been in plenty of cars fitted with them driven on the street.
Post Posted: Tue Apr 19, 2011 8:58 am
Another vote for the lockrights. I'm running them front and rear on my vit and love em, they have made the car ridiculously more capable.
That said:
1) I'd still take air lockers any day of the week if I was rich.
2) My car isn't a daily driver.
3) Get them set up properly. There was a world of difference between me guesstimating the backlash, and having a diff shop do it.
Bang for buck wise they are awesome. Can get front and rears delivered from the US for a shade over $600AU total.
Moses' SQ625 GV Pig
Post Posted: Tue Apr 19, 2011 9:02 am
Can some one correct me but i thought auto lockers never unlocked
They locked both wheels to turn min of pinion speed but allowed one side to over run the pinion speed for cornering .
If that's true then a auto locker would be better suited to the front the arb.
Post Posted: Tue Apr 19, 2011 9:22 am
That's pretty much how they work. Even when they do release the outside wheel they drive the inside wheel only and that alone resists steering. The front is always noticeable in 4wd with a lockright. But while a front is locked with an air locker the steering effect is much greater, that's when you turn it off, though sometimes when under load they don't unlock straight away.
Post Posted: Tue Apr 19, 2011 9:23 am
Yes but on low traction surfaces ( dirt, mud etc) it will not ratchet as easily. So it acts like a locked airlocker anyway.
Post Posted: Tue Apr 19, 2011 9:39 am
going from experience, and workin of competition vehicles,
detroits are stronger,
tho they are a litle annoying because the ratchet when turning under load, who cares,
having 1 in the front is still easy to turn, because u just back off turn the wheel and hit the power again, i have been in class 8 race cars running twin detroits and 35s never had a drama,
tho destroyed airlockers when running them constanlty in the back, more things to go wrong in an air locker
dodgy brothers mechanical
Post Posted: Tue Apr 19, 2011 10:41 am
The only thing user selectable in an air locker is the switch on the dash, even when you flick the switch off if the diff is still under load then it will stay locked until that load is removed making it no better then an auto locker. As far as the comp cars go from the ones I have seen over here it would be about 60/40 in favour of the auto lockers, largely due to the fact they arent driven on road. I run autos front and rear with PS, my hubs are never unlocked and its always in 4WD and the loss of turning circle isnt noticeable and speeds of around 90 odd kph they never played up.
For a DD and with money to burn I would consider an air locker based purely on on road manners, for a comp truck weekend toy, autos all the way.
Post Posted: Tue Apr 19, 2011 1:53 pm
I like to drive worry and stress free on road. I also like predictable handling. I could not cruise the mountain fire road as fast as I do if I had an auto-locker in the diff.
For me , the ARB is the only way to go. You get to have both, a locked rig when you need it, and unlocked when you don't. How can it gt any better than that?
Flip ..... Now you have lockers
Flip....... Now you don't
What is better than having that choice at your fingertips?
The only con I see is the price, and with your dollar being so strong buying them from low range should be about half price for you guys. No better time to buy IMHO.
Post Posted: Tue Apr 19, 2011 2:11 pm
air all the way, even after having the front one fail on me.
Post Posted: Tue Apr 19, 2011 4:24 pm
I've had a lockwrong in the rear for less than a week before I left the car behind, and I'm already sick of it on the road. Didn't get a chance to test it off-road, which may change the balance in my opinion, but so far just irritating!
Oh, and it came with a twisted Cromo axle! Bluddy comp trucks...
Post Posted: Tue Apr 19, 2011 4:47 pm
I recon most of the problem with lockrights is that most are set up wrong. U don't hear many proply saying they machined theirs to fit.
My mates got lockrights in his vit an u can't tell there in there. When I got mine done the guy f it it was to tight and bucked and kicked all over the shop. I took it back and he did something now it heaps better ,but not as good as the ones my mate did.
Post Posted: Wed Apr 20, 2011 4:26 am
So what can be done to a lock wrong to make them ratchet, or freewheel better?
Vehicle: Work van
Post Posted: Wed Apr 20, 2011 7:04 am
You would think so but it works out to be about 100 bucks cheaper than getting them locally :crazy:
Swb softie spoa cromo front -50 beadlocks 6.5s :D
Post Posted: Wed Apr 20, 2011 7:54 am
got a spartan locker in the rear of mine and will be getting one for my new sierra. put mine in myself and it was undrivable, clunky horror. took it back out and gave it to a diff specialist, $90 later put it back in and it is amazing. made a bit of noise for a few months but now its is only a very quiet ticking around corners. people in the car dont even notice it
Users browsing this forum: No registered users and 351 guests
