It is currently Sat Nov 07, 2026 2:59 pm
Post Posted: Mon May 09, 2011 1:36 pm
I'm trying to get to my Vitara transfer guts to install my reduction gears.
For the love of god I must be missing something. I cannot break the transfer away from the gearbox! I have undone all external 12mm bolts around the case near the gb mount and also the next set of 12mm further up with no luck. I'm not going to tell you how hard I've hit the prick just incase I have missed something! Ha.
Thoughts and advice apreciated.
Btw I have the whole gearbox on the workbench.
Post Posted: Mon May 09, 2011 1:43 pm
taken the shifter housing off the top?
Post Posted: Mon May 09, 2011 1:59 pm
No. I understand there is only one 12mm bolt going into the transfer case at the back of shifter housing? The front ones are directly into the gb?
Do these front ones need to come out to split?
Post Posted: Mon May 09, 2011 2:07 pm
If I recall correctly, yes.
Still, it won't hurt for you to take the shifter off.
Post Posted: Mon May 09, 2011 2:13 pm
Beauty. Thanks I'll pop it off tomorrow and see what unfolds.
Post Posted: Mon May 09, 2011 7:35 pm
under the shifter housing there is another long bolt
Post Posted: Mon May 09, 2011 8:43 pm
x2 took me ages to find it
Post Posted: Mon May 09, 2011 9:11 pm
Knew there must be something. Thanks so much guys.
Post Posted: Tue Jun 07, 2011 7:52 am
Need clarification. Please.
The shifter housing of the gearbox has to come off first,
before transfer case will come off :?
(not the transfer shifter?)
Tho that comes off to fit the gears anyway. :roll:
I been studying the fitment of crawler gears,
getting closer to purchase.
Anybody wish to buy my soul :twisted:
Post Posted: Tue Jun 07, 2011 10:24 am
that is correct....
At least I know it is for a manual. What about the auto?
Post Posted: Tue Jun 07, 2011 10:27 am
that is correct....
good point, thanks, better look into that.
shifters a cable, so probably be easier, hopefully
Post Posted: Thu Sep 15, 2011 4:34 am
Pulled the transfer out today.
With an auto, body lifted LWB Vitara,
You can get T-case off without dropping the auto out :)
With the gear shifter out, there was enough room to get at the top bolts.
Removing the cross member left access for the rest.
Had to use 1/4 drive though,
1/2 " was able to crack a few,
but not many,\
dont have a 3/8ths set,
but a 3/8ths could fit.
Also the hidden top long bolt,
is not hidden by a gear stick in an auto,
it is a cable shift.
Users browsing this forum: Google [Bot], phlix and 58 guests
