It is currently Sun Aug 02, 2026 4:19 am
Post Posted: Sat Jun 18, 2011 12:16 am
i have a 99' jimny (with free wheeling hubs) and every now and then the 4wd wont work (the hubs are lokced in) they will only work wen i really dont need 4wd it like they have a mind of there own its really pissing me off cause i feel like a dick wen i cant get up a hill.
Post Posted: Sat Jun 18, 2011 12:32 am
Pull you hubs off, give em a clean up and re-grease
Post Posted: Sat Jun 18, 2011 1:07 am
yeah you'll fine one or both hubs are clogged up and not locking in and then the diff sends all the power to the unlocked axle.
i wrote a tutorial on rebuilding hubs, its in the "good tech" section.
Post Posted: Sat Jun 18, 2011 1:41 am
thanks heaps people thought it would be that is it hard to pull them off ?
Post Posted: Sat Jun 18, 2011 2:07 am
easy as... just need basic tools, some degreaser / petrol to clean it all up with and some bearing grease (with lithium) to lube it up!
tutorial is here: http://www.auszookers.com/index.php?nam ... light=hubs
Post Posted: Sat Jun 18, 2011 2:12 am
sweet i no wat iam doin this arvo.
Post Posted: Sat Jun 18, 2011 2:39 am
Just make sure you read Aliens stuff well.
I am reasonably mechanically minded, and so, pulled the hubs off, stripped them, put them back together, an thought, crikey, that was easy, when I put them back on, no go ???
Anyways, ended up doing the first one about a zillion times, very simple little shit things that you dont think means anything, but well explained in aliens write up.
Once I had seen my fuckup, other side took SFA time.
Post Posted: Sat Jun 18, 2011 4:02 am
Yeah, definitely check that your hubs are locking properly.
I had the exact same problem the first time I ever took my Vit out. Turns out both my hubs weren't properly engaging.
My suggestion is to check that out BEFORE you end up 40 clicks from the nearest road :roll:
What do you MEAN "That JCB won't fit"?!
Post Posted: Sat Jun 18, 2011 4:21 am
I used to just engage them, then hit them with a rock to be sure they were in. Then I got the Pathfinder with auto-hubs and realised how good the manual hubs were even with their faults.
Post Posted: Thu Jun 23, 2011 4:49 am
thanks heaps people they are working now just needed a good clean and grease but the bolts that where holding them on where really loose and i had one missing but wen i put them back on i tightend them as much as I could (sat night) went 4wding on sunday hubs where good then cleaned the car wednesday night and wen i was cleaning the wheels i looked at the hubs and all the bolts except for 1 where holding the hub on so i got a couple of bolts from the other side and done them up and drove it to work and iam just about to put the new bolts in now with LOCTITE so i hope they wont come out now
Post Posted: Thu Jun 23, 2011 5:07 am
If you don't go 4WDing very often, you should take them off and clean them every 4-6 months of them not being in use. They seize up else.
Users browsing this forum: Google [Bot] and 152 guests
