It is currently Fri Nov 06, 2026 9:20 pm
Vehicle: LPG 1.6 Sierra
Post Posted: Thu Jun 30, 2011 8:54 am
I need to get an adaptor plate made up to fix a throttle body to the zook manifold.
I've taken the measurements from dead centre of the mounting holes of the TB and manifold:
The plate will have to be about 10mm thick, and look something like this:
The red holes indicate the throttle body mounting position, and will need to be threaded to secure the TB to the plate.
The yellow holes indicate the manifold position, and holes will need to be countersunk so not to interfere with the TB.
Anyone here up for the job? Shoot me a price and i'll tee it up
Post Posted: Thu Jun 30, 2011 10:05 am
With your design. I would be matching the intake to the TB not the manifold. Ie just a hole, not an oval. Then port to match. Will also simplify the design of the adapter plate.
Lil Foot!
Post Posted: Thu Jun 30, 2011 10:07 am
yeah then its just someone with a drill press and a 50mm holesaw to make it =)
Andrew aka Monkey might be able to make this...
Post Posted: Thu Jun 30, 2011 10:20 am
alien wrote:
Andrew aka Monkey would wanna bloody hope to be able to make this...
:lol:
Post Posted: Thu Jun 30, 2011 10:22 am
given how long he's taken to make his sliders im not so sure =P
Post Posted: Thu Jun 30, 2011 10:28 am
If you get stuck, let me know.
Post Posted: Thu Jun 30, 2011 10:32 am
Haha, true.
Post Posted: Thu Jun 30, 2011 10:44 am
:thefinger:
Post Posted: Thu Jun 30, 2011 10:46 am
Yeah will do, I just put an oval shape to show there's a hole there :) Gimmie a basic hole and then i'll port it out to suit both pieces - the drilling I can't do myself :cry:
Not done with the manifold hole yet - there's still enough beef on the intake manifold to widen for a more circular routing if need be, but i'll wait until I got all the bits in front of me before I do anything more.
Post Posted: Thu Jun 30, 2011 11:00 am
Will do mate :) Thanks for the offer
Post Posted: Fri Jul 01, 2011 8:13 am
Where to buy aluminium flat bar offcuts?
I need a 70mm x 100mm x 12mm piece - stopped through Metal Land and another metal yard on the way home and but 3 metre lengths is their minimum order... waaay more than I need
Post Posted: Fri Jul 01, 2011 8:27 am
theres a few aluminium fabricators in wangara mate, give them a call on monday.
Post Posted: Fri Jul 01, 2011 8:33 am
timmay made mine, i got the chunk of 6061 from ulrich alu mine was a bit bigger tho, and my holes were really close to each other so i had to use one hole for both TB and manifold
and this is what he sent back
for that chunk of alu it cost me $75 110x115x25 from memory plus tim's rates....
Vehicle: Work van
Post Posted: Fri Jul 01, 2011 8:55 am
He must be goode to make that from the technical drawing you gave him :D
Swb softie spoa cromo front -50 beadlocks 6.5s :D
That's the ticket.
Will Aluminium be good enough for the job or is 6061 alloy the way to go?
Vehicle: Daisy
Post Posted: Fri Jul 01, 2011 9:22 am
What about an electrical contractor? I know we used to have a heap of scrap ally laying around, just depends how thick you need I guess.
Or maybe a scrapyard, they might sell you a small bit.
Post Posted: Fri Jul 01, 2011 10:15 am
Ebay :) Always to the rescue
http://www.ebay.com.au/itm/Aluminium-Fl ... 500wt_1156
Post Posted: Fri Jul 01, 2011 10:20 am
I am Timaay! Incase you didnt know.. :lol:
Post Posted: Sat Jul 02, 2011 4:17 am
6061 is just machine grade alloy.....
don't quote me, im a boilermaker, thats just what my research told me :lol:
Post Posted: Mon Jul 04, 2011 8:17 am
Che, that little hole in the manifold to the right in your picture..By yourself a 1/4" round stick of aluminum, cut it to length, then heat the 1/4" rod and swedge (read pound) it in with a wooden mallet.
This does two things, #1 prevents a common source for vacuum leaks. #2 fills the hole so you can port the intake/plenum area to your hearts content.
Also, take a dremel tool, or whatever you have and round out the corners below the plenum.
That little hole goes to the air inductor nozzles inside the intake ports in the head. They are supposed to promote swirl in the combustion chamber, but are no longer needed, so plugging the port just gives you a little bit more room to port, and seals up a common vacuum leak.
Don't port it out bigger, just smooth the corners and make the transition into the two runners nice rounded and smooth.
There is more to do internally, but that should help quite bit with flow and velocity into the runners. You really should port the inside of the runners if you want the most efficiency you can get out of the manifold (power and mileage).
Users browsing this forum: Google [Bot], Google Adsense [Bot] and 100 guests
