It is currently Fri Nov 06, 2026 9:20 pm
Post Posted: Tue Jul 05, 2011 7:49 am
hey guys with the missing links from low range is there anything special that i have to have done to my car (ruf, yj,cj leaf swap) or can they bolt onto standard, 2inch lift like drop shackles or climax shackels?
Vehicle: 2018 DMAX
Post Posted: Tue Jul 05, 2011 7:55 am
There missing links, are suited to a spring thats 'around' 3inchs longer, give or take. So that would be rears up front, and longer than rears in the rear, like CJ7 springs. You will want longer shocks and longer brake lines, drive shaft extensions.
The missing links that you use with a YJ springs are different, the YJs are a wider spring than the sierra/CJ7 spring.
Chances are its not just going to be a bolt up job.
Post Posted: Tue Jul 05, 2011 9:52 am
for the amount of effort you're going to go to you might as well do a 3/4 elliptical in the ass end, at least then the extra droop is sprung.
Users browsing this forum: Google [Bot], Google Adsense [Bot] and 102 guests
