hey guys with the missing links from low range is there anything special that i have to have done to my car (ruf, yj,cj leaf swap) or can they bolt onto standard, 2inch lift like drop shackles or climax shackels?
Joined: Tue Jun 29, 2010 7:44 am Posts: 2003 Location: Brisbane
Vehicle: 2018 DMAX
Posted: Tue Jul 05, 2011 7:55 am
There missing links, are suited to a spring thats 'around' 3inchs longer, give or take. So that would be rears up front, and longer than rears in the rear, like CJ7 springs. You will want longer shocks and longer brake lines, drive shaft extensions.
The missing links that you use with a YJ springs are different, the YJs are a wider spring than the sierra/CJ7 spring.
Chances are its not just going to be a bolt up job.
Users browsing this forum: Google [Bot] and 64 guests
