It is currently Fri Nov 06, 2026 11:19 pm
Post Posted: Tue Jul 19, 2011 1:59 pm
on my wt sierra am i gona have to drain the radiator inorder to change the temperature sender on the water pump.
THINKING BEFORE POSTING!!!
Post Posted: Tue Jul 19, 2011 2:01 pm
Can't just quickly swap it over?
Temp sender in water pump??
Post Posted: Tue Jul 19, 2011 2:06 pm
im prety sure its the water pump lol im still learning about cars lol. im used to dirtbikes hahah.
its on the front left side of the engine (1.3litre) when ur standing infront of the car looking at the engine about 10-15 cms behind the left edge of the radiator. im thinking i should probably just be able to jack that side of the car up. hopfully and quickly change like u said. i just filled it up with coolant :(
Post Posted: Tue Jul 19, 2011 2:13 pm
Temp sender is screwed into thermostat housing
Post Posted: Tue Jul 19, 2011 2:24 pm
dose this mean when i pull it out coolant isnt gona piss out everywere all over my parents driveway
Post Posted: Tue Jul 19, 2011 2:29 pm
Won't be much pressure in the lines and the sender is pretty much neally the highest point so it might drible out.
Nothing a finger can fix
Post Posted: Tue Jul 19, 2011 2:49 pm
awsome thanks for that.
Post Posted: Tue Jul 19, 2011 3:14 pm
take your radiator cap off to release any pressure then put it back on before you remove the sender .
(putting it back on will slow the coolant down being released)
also put a bit of thread tape on the new sender
lost in suzuki space
Post Posted: Tue Jul 19, 2011 3:29 pm
ok awsome thanks for the help guys shall do it tomorrow
Post Posted: Tue Jul 19, 2011 6:50 pm
Do it when cold, you will lose bugger all, be quick, and a few drops, no more will leak out.
There will be no pressure inside the water column, and also the whole thing is sealed, so a 1/4bsp ( I think) hole should be able to stay open an hour without any significant leakage.
Post Posted: Tue Jul 19, 2011 10:33 pm
I did mine that way, only prob was an air lock formed in cooling system. Running engine with rad cap off for a while fixed that.
Post Posted: Wed Jul 20, 2011 6:51 am
how did u tell that an air lock had formed
Post Posted: Wed Jul 20, 2011 7:12 am
Mines a Vitara EFI, it had erractic idle and missing.
Probably never happen in a sierra, different set up.
Should be fine.
Users browsing this forum: DesmondTheDrover and 81 guests
