It is currently Mon Aug 03, 2026 3:35 pm
Post Posted: Thu Jul 21, 2011 1:09 am
vitara steel house for 92 vit whats needed
Post Posted: Thu Jul 21, 2011 3:07 am
Have a search, there is plenty on here about it.
Put a little effort in and people will help you out
Post Posted: Thu Jul 21, 2011 3:41 am
The housing, everything else will bolt up.
Post Posted: Thu Jul 21, 2011 6:13 am
buzbox did his not to long ago after breaking 2 alloy ones I was there of one of them
 Profile YIM
Post Posted: Thu Jul 21, 2011 6:17 am
isn't bolting it up is the easy bit, pretty sure there is more to it than that.
Post Posted: Thu Jul 21, 2011 8:54 am
Beer, and plenty of it too. :blink:
Post Posted: Thu Jul 21, 2011 8:56 am
I did this mod a couple of years ago. Changed axle and diff housings to steel. fairly easy, you have to pull the axles out, be carefull not to damage the seals in the donor housing when you put the axles back or you will have an oil leak that you will only discover when it is all back together. Some oil on the seals before sliding axles in will help.
Post Posted: Thu Jul 21, 2011 9:06 am
do you have to worry about changing the diff ratio's?
Post Posted: Fri Jul 22, 2011 8:22 pm
Ratios depend on what you are using it for, but make sure that the new diff is the same as the old one or the rear. You may have to swap over the crown wheel and pinion to do this.
Users browsing this forum: No registered users and 232 guests
