It is currently Mon Aug 03, 2026 12:51 am
Post Posted: Wed Jul 20, 2011 9:54 pm
2nd and 4th gear keep popping out after I installed a 2" body lift & 40mm suspension lift.
Any ideas what's causing it & is there an easy fix?
Post Posted: Wed Jul 20, 2011 10:02 pm
Impossible! Never heard of it!
Have you done a search? This has been covered countless times. You need to open up the shifter hole in the floor.
Steve
Post Posted: Wed Jul 20, 2011 10:25 pm
Grimbo'd ^^
Post Posted: Wed Jul 20, 2011 10:32 pm
No worries fellas, my bad.
Post Posted: Wed Jul 20, 2011 10:52 pm
your gear lever may be hitting the floor, few ways to fix it, cut the hole bigger or even hit the floor down,
or bend the lever, we had the same problem
dodgy brothers mechanical
Vehicle: 4wd
Post Posted: Wed Jul 20, 2011 11:30 pm
Here's a link that may help:
http://www.auszookers.com/index.php?nam ... pping+gear
Watch out or you'll get sued.
Post Posted: Thu Jul 21, 2011 2:37 am
Gear lever is hitting the floor mate, I just put a 2" body lift in mine and had the same issue. I wouldn't cut into the body. I'd bend and extend your gear levers 2"s, you'll have the same issue with your transfer case lever.
Matty
Post Posted: Thu Jul 21, 2011 3:56 am
get a heat torch and bend the buggers, once this was done i had no problems
Vehicle: SJ80, SE416
Post Posted: Thu Jul 21, 2011 4:38 am
On my coily with 2" body lift the problem isn't the gear stick hitting the cutout, it's the tension the rubber boot creates when it is bolted in place. Unbolt it (I stuck mine back in a new position with race tape), and there is no problem. Also I have no problem with the transfer lever - the lever just has to be pushed against the limits of the cutout but it still functions fine.
Post Posted: Thu Jul 21, 2011 6:19 am
loosen your body mounts and push the body forward on the chassie
 Profile YIM
Vehicle: SJ80
Post Posted: Thu Jul 21, 2011 6:26 am
x2 about the rubber boot on a coily.
Vehicle: 4wd
Post Posted: Thu Jul 21, 2011 6:51 am
That would make it worse.
Post Posted: Thu Jul 21, 2011 9:30 am
With mine we just turned the rubber boot around and put a slight bend in the lever. Makes it perfect.
Post Posted: Thu Jul 21, 2011 9:47 am
I'm not a fan of bent gearlevers.
Post Posted: Thu Jul 21, 2011 9:57 am
do a transfer lift =)
Post Posted: Thu Jul 21, 2011 11:25 am
I sorted it on my vit with 2in lift bending the gearstick about 70deg and putting in backwards! perfect :)
Post Posted: Fri Jul 22, 2011 5:40 am
same i just took my shifter stick out put in in a vice and bent it. had to use a pipe to make it a bit easier to bend. didnt have to bend it too much. saves cutting your car up
Post Posted: Fri Jul 22, 2011 7:17 am
well push the body the other way :roll:
 Profile YIM
Users browsing this forum: Google [Bot] and 222 guests
