| Author |
Message |
trity
Joined: Wed Jan 05, 2011 9:49 pm Posts: 250 Location: Perth, WA
 Posted: Thu Aug 04, 2011 12:12 am |
i am currently running the standard Z172 filter on my 91 sierra but am going to install an oil filter sandwich plate so i can run some gauges
my question is since the plate is a little under 1in thick i'm going to need to run a smaller filter as it will more than likely hit the engine mount
i've read a Z418 filter has the same thread and is smaller but are there any complications with running a smaller filter?
alien
Joined: Wed Mar 24, 2010 10:30 pm Posts: 16343 Location: Perth
 Posted: Thu Aug 04, 2011 12:13 am |
i run z418 on mine no worries at all and have been for about 8 years now.
trity
 Posted: Thu Aug 04, 2011 12:16 am |
cool good news do you run a sandwich plate or is there another reason you run the smaller filter?
Jester
Joined: Fri May 08, 2009 11:30 pm Posts: 726 Location: Adelaide
 Posted: Thu Aug 04, 2011 12:20 am |
I run the 418 on my vit, its the standard fitment on a baleno, and so much easier to get a hold of.
alien
 Posted: Thu Aug 04, 2011 12:22 am |
i was running the 1.3 which had no need for it really, was just easier to get at the time i think... now running 1.6 its standard fitment on that so yeah.
trity
ah good to know thanks well it looks like im changing to the 418 from now on then
Santos
Joined: Tue Jun 09, 2009 11:30 pm Posts: 1009 Location: Sydney -ish
Vehicle: 92 Suzuki Sierra
 Posted: Thu Aug 04, 2011 12:24 am |
i think from memory the z418 is used in newer model suzuki's for clearance reason (if not i know there is a squatter shaped filter that is listed as compatible for late model suzuki's ) If you change your oil regularly it shouldn't be an issue
Have you checked to see if the z172 actually hits? Just unscrew your existing one and test fit. a v8 Z9 filter fits and its freakin huge.
_________________ -Santos
Jester
 Posted: Thu Aug 04, 2011 12:27 am |
Santos wrote: i think from memory the z418 is used in newer model suzuki's for clearance reason (if not i know there is a squatter shaped filter that is listed as compatible for late model suzuki's ) If you change your oil regularly it shouldn't be an issue.
The 418 is standard fitment on v6 prados, so id think it has the capacity required
trity
 Posted: Thu Aug 04, 2011 12:33 am |
yeah i am just waiting for my sandwich plate to turn up then i can trial fit but if the 418 is used without an issue i'll just run the smaller filter
joel
Joined: Wed Jan 27, 2010 10:30 pm Posts: 2191 Location: Dirranbandi
Vehicle: Sj70 tintop
 Posted: Thu Aug 04, 2011 12:55 am |
ryco z125 fits, and is pretty small.
howd you go with your fuel drama?
_________________ Sj70 tintop
trity
 Posted: Thu Aug 04, 2011 1:01 am |
yeah seems to have sorted itself out but i honestly think it picked up some shit from the fuel tank and was a small blockage
ran it last night for a while without a drama
Scrawny
Joined: Tue Jan 29, 2008 10:30 pm Posts: 10528 Location: Brissie
 Posted: Thu Aug 04, 2011 1:37 am |
Jester wrote: Santos wrote: i think from memory the z418 is used in newer model suzuki's for clearance reason (if not i know there is a squatter shaped filter that is listed as compatible for late model suzuki's ) If you change your oil regularly it shouldn't be an issue. The 418 is standard fitment on v6 prados, so id think it has the capacity required
Most late model Toyota's with a screw on filter run the 418, Hilux, Hiace, Camry, etc
royce
 Posted: Thu Aug 04, 2011 2:07 am |
and mini's
shep
Joined: Thu Mar 29, 2007 11:30 pm Posts: 14498 Location: Here there everywhere
 Posted: Thu Aug 04, 2011 3:57 am |
and yamaha 1600efi outboards
_________________ JEEPJEEPJEEPJEEPJEEPJEEPJEEPJEEPJEEP
trity
 Posted: Thu Aug 04, 2011 3:59 am |
geez no wonder the 418 is easier to source
squizzytaylor
Joined: Sat Sep 26, 2009 11:30 pm Posts: 381 Location: Bogged near Morisset
 Posted: Thu Aug 04, 2011 4:17 am |
Hmmmmm, any reason you need a sandwich plate to run gauges?
You can but t-adapters that screw into the oil pressure switch port on the block.
trity
 Posted: Thu Aug 04, 2011 4:28 am |
can you? sorry im all new to gauges etc
what i have is an electronic oil temp gauge with sender so im trying to figure out the best way to fit the sender - so far i can only find these sandwich plates?
trity
 Posted: Thu Aug 04, 2011 4:44 am |
are all threads for the t-piece 1/8th NPT?
squizzytaylor
 Posted: Thu Aug 04, 2011 5:09 am |
trity
 Posted: Thu Aug 04, 2011 5:25 am |
cheers mate that looks like a better option
oozuk
Joined: Sun Aug 16, 2009 11:30 pm Posts: 1452 Location: bethania QLD
 Posted: Thu Aug 04, 2011 6:42 am |
there's also two oil gallery ports side by side on the G-series block that you can screw oil gauges into and still run the factory pressure switch
_________________ building a bling zook .......will it ever be finis
Bazooka
Joined: Wed Dec 22, 2010 9:12 am Posts: 38 Location: SOR Perth WA
 Posted: Thu Aug 04, 2011 8:37 am |
So does anyone know the number of the filter for a 2.4 GV (2009)
Built4thrashing
Joined: Wed May 21, 2008 11:30 pm Posts: 4972 Location: Dandenong .Vic
 Posted: Thu Aug 04, 2011 9:12 am |
Bazooka wrote: So does anyone know the number of the filter for a 2.4 GV (2009)
Have you bothered to search the RYCO website. Its listed in their online catalog. Z734
_________________ B4T
TheOtherLeft
Joined: Sun Aug 27, 2006 11:30 pm Posts: 818 Location: Sydney
 Posted: Thu Aug 04, 2011 9:31 am |
Built4thrashing wrote: Bazooka wrote: So does anyone know the number of the filter for a 2.4 GV (2009) Have you bothered to search the RYCO website. Its listed in their online catalog. Z734
But asking on forums is so 2011. Researching for yourself was so last year... hell even last decade.
_________________ 2002 SWB GV
Lifted and Locked
trity
 Posted: Thu Aug 04, 2011 10:49 am |
oozuk wrote: there's also two oil gallery ports side by side on the G-series block that you can screw oil gauges into and still run the factory pressure switch
oh are you talking about the one right beside it with like and allen key plug?
oozuk
 Posted: Fri Aug 05, 2011 9:59 pm |
trity wrote: oozuk wrote: there's also two oil gallery ports side by side on the G-series block that you can screw oil gauges into and still run the factory pressure switch oh are you talking about the one right beside it with like and allen key plug?
Yep
trity
 Posted: Sun Aug 07, 2011 11:17 pm |
hmmm might not be able to use that on the allen key plug won't budge
