It is currently Mon Aug 03, 2026 9:53 pm
Vehicle: 89 Vit. The Desert Rat...
Post Posted: Sat Aug 20, 2011 7:38 am
Hi All,
I went to change my timing belt and water pump today, but found that there was a bolt for the cover under the water pump that was really hard to get to.
My question is: do you normally remove the alternator to get at that bolt?
I packed it in for the day as it figured that if I have to remove the alt
I may as well throw a falcon one in while I'm at it.
What's everyone's thoughts?
Post Posted: Sat Aug 20, 2011 7:56 am
You pull the belt and water pump pulley off but you dont have to pull the alternator off
I dont know that any cover bolts are hard to get to, I can do a belt in an hour so it must be easy if it was hard it would take me 2 days to get round to it :)
Post Posted: Sat Aug 20, 2011 8:00 am
1 hour for you probably means two for me. :blink:
Still means a easy job. :D
Ok thanks. I'll give it a proper shot in the morning.
Post Posted: Sat Aug 20, 2011 8:03 am
if you remove the fan belt, then the fan and pulley for the waterpump along with the fan shroud youll have a heap more room and everything will be a lot easier to get at
Post Posted: Sat Aug 20, 2011 8:08 am
I looked at removing the shroud, but I thought I could reduce the workload by leaving it in.
Probably, false economy.
Post Posted: Sat Aug 20, 2011 8:10 am
its a lot easier to pull the fan and shroud out in one go and its an easy shroud to move
then you have more room to swear at the big crank pulley bolt :)
Post Posted: Sat Aug 20, 2011 8:18 am
haha... I was kind of hoping I won't have to change that one.
But I better do it anyway then I shouldn't have to worry about it again.
I've printed out a few threads on it for reference.
Going to be lots of pics. :D
Post Posted: Sat Aug 20, 2011 8:20 am
do the seals, f you dont youll be in there again later :wink:
Post Posted: Sat Aug 20, 2011 8:23 am
Yeah, it's a pain having to do the job twice
Post Posted: Sat Aug 20, 2011 10:54 pm
You were so right. Much easier.
Now it's just that stupid F@$#^&g crank pulley bolt. :twisted:
Post Posted: Sat Aug 20, 2011 11:12 pm
Put a socket and power bar onto the bolt and lean the handle on the passenger chassis rail. Then just give the key a flick. The starter will spin the engine momentarily and the bolt will come undone
Post Posted: Sat Aug 20, 2011 11:17 pm
Thanks Scrawn.
Will do. I'm just waiting for the neighbour to come home so I can borrow his breaker.
Mine isn't big enough.
Post Posted: Mon Aug 22, 2011 2:39 am
Well that was a bust.
Ended up with a flat battery. :blink:
I'll try again next weekend after I buy a decent sized breaker, and a new battery. :oops:
Users browsing this forum: Google [Bot] and 59 guests
