It is currently Thu Aug 06, 2026 6:52 pm
Post Posted: Fri Sep 23, 2011 4:21 am
I'm going to do this install. I would like some advice. Has anyone done this using the standard ecu and loom and ignition? Was there any probs with the traction control? Also to clarify on the engine mounts, something about jimny and Sierra mounts? Thanx
Post Posted: Fri Sep 23, 2011 10:43 pm
So nobody knows about this then, I'll let you's all know how to do it in a few months
Post Posted: Fri Sep 23, 2011 10:56 pm
Mate our M15 swift's didn't come out here with TC unless it was a Sport (M16) & that was an option, till last yr....
Just run a stand alone ECU, then you don't have worry about any other system the car ran... ( like Immobilizer)
Post Posted: Fri Sep 23, 2011 11:56 pm
Cheers mate that's good to know. I'm going to run the standard ecu with all the components it needs to run. Is there any problems that I may run into doing this?
Post Posted: Sat Sep 24, 2011 1:12 am
The imob need's the dash cluster, the dash is "can-bus"...
Have fun, if you do work a way around using 1/2 the swift I would like to know.
Or, find a vvt jim & steal it's eng management & imob, or buy a wreck, cause you'll need lot's of bit's from it anyway, like g/box, starter, intake manifold ect, ect, ect....
Hope that help's mate.... :helloo:
Post Posted: Sat Sep 24, 2011 1:33 am
Yeah got all that stuff. But not the m13a loom I think it may be possible with the m15a loom but also there may be a reason that it seems that it hasn't been done before
Post Posted: Sat Sep 24, 2011 2:01 am
Immob :helloo:
Post Posted: Sat Sep 24, 2011 2:29 am
i can't see why you can't transplant the factory immob into the sierra, surely it's only the factory immob module, an antenna around the key barrel & the transponder key? i'm not sure on how the suzuki immob works but on a mates L series subaru, we put in a 2005 2.5L Forrester motor & transferred the factory immob all over, got a transponder key cut, then coded & it started first time.
Post Posted: Sat Sep 24, 2011 2:30 am
:helloo: Guss...
Post Posted: Sat Sep 24, 2011 2:31 am
You might be able to do it with a jimny cause its a separate box that tells the ecu its good to go but in the swift its in teh bcm that talks to everything including the dash cluster via a serial link not just volts on wires
Post Posted: Sat Sep 24, 2011 2:32 am
You have such a way with word's.... :D
Post Posted: Sat Sep 24, 2011 2:33 am
epic reading fail, missed the can-bus bit :oops:
Vehicle: Suzuki Jimny
Post Posted: Tue Feb 14, 2012 3:51 pm
Did you ever sort it out I want to put one in a lj80 I have or will have the loom and computer and immobilizer key what else ? Transponder ring got that
Any 4wding
Post Posted: Tue Feb 14, 2012 11:40 pm
No not yet I've been getting all the things together that I need I will be starting on it in a month. As far as I can tell the biggest issues are the vss and a hybrid gearbox needs to be made. All jimny engine components need to be used eg, inlet exhaust man, sump and pickup. As for any other probs I will only find out in a month as I'm doing it. Sorry I can't be of more help.
Post Posted: Wed Feb 15, 2012 7:17 am
Thank you
Any 4wding
Users browsing this forum: Google [Bot] and 774 guests
