It is currently Sat Nov 07, 2026 4:53 pm
Post Posted: Sun Oct 16, 2011 10:56 am
Hi guys I have a vit swb I am looking at the masterkit1 on ebay its a 2inch coil lift (spacers) and a 3 inch body lift. Does anyone have any thoughts on this kit. Good or Bad? or any other alternatives in the same price range $850
Post Posted: Sun Oct 16, 2011 10:59 am
In my opinion 3" body lift is too much, you can run into a few problems.
Look in the business section, AZ has a good 2 " body lift kit maker.
Post Posted: Sun Oct 16, 2011 11:03 am
Where do I find the business section in AZ
Post Posted: Sun Oct 16, 2011 11:04 am
http://auszookers.com/index.php?name=Fo ... forum&f=15
Vehicle: SJ50 hardtop!
http://www.auszookers.com/index.php?nam ... ic&t=15518
NT SJ50
Post Posted: Sun Oct 16, 2011 11:05 am
well it sounds shit imo why do u want to lift it?and i agree 3inch body is to much coil spacers will not help with flex or anything thing so if ur looking for flex get a proper kit with coil's and shocks
if u drive a loud toyota ute u drink rum
Post Posted: Sun Oct 16, 2011 11:13 am
I want to lift so I can keep up with my mate in his patrol 4 inch suspension lift (no wife and kids money to burn) On the other hand I have the ball and chain and donthave money to burn. Do you have any ideas on what to get in the same price.
Post Posted: Sun Oct 16, 2011 11:17 am
That's no hard :lol: should be able to do that as a stocker, cus zook are wicked :wink:
And as other have said 3" BL is to much, so 2" from the business section is the way to go. :wink:
Post Posted: Sun Oct 16, 2011 11:21 am
My version of fun on the cheap:
50mm body lift off justcruizin here on the forum
50mm coil spacers off Bruce here on the forum
Gabriel commodore shocks for the rear from Supercheap
Strut mount flip at the front and keep the stock struts.
2nd hand set of 30s or 31s depending on how much you want to pooch your gearing.
DIY some extended bump stop spacers.
Should be able to do the lot for a bit over $500 and will give you a shit tonne more clearance.
That is essentially what I am running in mine still with just a couple of extras (except I've got ridepro struts instead of doing the mount flip).
Moses' SQ625 GV Pig
Post Posted: Sun Oct 16, 2011 11:27 am
Easy:
Calmini 3" Super Articulation Kit from Lowrange
http://www.lowrangeoffroad.com/index.ph ... ystem.html
Mini Spool from Lowrange
http://www.lowrangeoffroad.com/index.ph ... 043-3.html
This combo will let you show him what real 4wding is all about ;)
Post Posted: Sun Oct 16, 2011 11:29 am
I think another important question...what is you budget for the build?
Post Posted: Sun Oct 16, 2011 11:30 am
The calmini kit looks nice. Got some movement. but out of price range
Will follow up on Bruce and justcruzin sounds like the right price thanks
Post Posted: Sun Oct 16, 2011 11:49 am
if it was me i would lock the rear and just get a ebay suspenion lift kit 2inch or so and look for some cheap muddies
Post Posted: Sun Oct 16, 2011 12:04 pm
I already have 30 muddies which have made a huge differance going up muddy hills doesnt help turning corners with them hitting the guards thats another reason why I want the lift sick of putting stockies back on for the black stuff
Vehicle: Jeep
Post Posted: Sun Oct 16, 2011 12:30 pm
What is your price range ???
I couldnt find the masterkit1 one you were talking about... got a link to it ?
There are a few good options for lift kits on ebay... personally, i wouldnt buy anything i have never heard of before... i just did a search on ebay, here is what came up -
http://www.ebay.com.au/sch/i.html?_nkw= ... m270.l1313
Post Posted: Sun Oct 16, 2011 12:41 pm
mate i run the cheaper style set up, but i run 180sx rear springs (50mm lift) in stead of standard plus spacers.
flex is pretty good condisering i have only spent about $120 on the rear not inc tyres ($50 for springs $50 for shocks, $20 for shock relocation brackets)
stock;
im an apprentice so $$ is always low, if $ is an issue then this is better that spacers. this set up gets me along way down the track, throw in a locker and 31's ur set.
Post Posted: Sun Oct 16, 2011 12:47 pm
given all that - a locker in the ass end would get you further than 1-3" more flex...
Post Posted: Sun Oct 16, 2011 8:18 pm
sorry guys dont know how to do links but the item numbers on ebay are 230676120318 for the body lift
230568785002 for the ciol and body lift
Post Posted: Sun Oct 16, 2011 11:47 pm
Weld both the diffs $5 worth of rods and you will kill your mate.
Vehicle: Jeep
Post Posted: Mon Oct 17, 2011 2:46 am
This is them -
Body lift - http://www.ebay.com.au/itm/230676120318 ... 3D1&_rdc=1
Coil and body lift - http://www.ebay.com.au/itm/230568785002 ... 3D1&_rdc=1
These are in Canada, and are an unknown brand here, i wouldnt get them... get something locally ! :wink:
Post Posted: Mon Oct 17, 2011 6:11 am
Yes that is the link to what i was talken about. 1 of my mates just gave me 35mm coil spacers he has told me this will be enough for the 30s to clear the guards. Is it worth putting a body lift in or would it be just looks
Post Posted: Mon Oct 17, 2011 6:16 am
No amount of suspension lift/coil spacers will make the tyres clear the guards since it will still compress the same amount when articulating. You'd need to extend the bumpstops at the same time.
If you aren't planning on going bigger than 30s I wouldn't worry about the body lift. Just extend the bump stops and use a hammer to clearance any problem areas.
Moses' SQ625 GV Pig
Users browsing this forum: No registered users and 50 guests
