Posted: Mon Oct 17, 2011 6:49 am
If you do replace the whole thing, tie some strong'ish wire round it before you pull the cable from behind the heater & use it to pull the new one through...
It's best to run em where in the original place's, or you'll get a jumpy speedo or a short life out of the cable...
Joined: Thu Dec 23, 2010 7:42 pm Posts: 489 Location: Macleay Island
Posted: Wed Oct 21, 2015 7:43 am
I read yesterday where you don't have to drop the cluster, I got my hand up there, but couldn't pull it off. Does it half turn first, or use more force ? Replacing the inner cable only, do I just assume the outer is good behind the heater ?.
Can't say much about the outer but I know to pull it off the cluster I just gave it a good yank and a slight twist at the same time. Think like pulling an aerial cable off a TV.
Users browsing this forum: Google [Bot] and 313 guests
