It is currently Thu Oct 22, 2026 9:45 am
Post Posted: Sun Oct 16, 2011 1:20 am
Hey all trying to put new speedo cable in . Wats the easiest way having trouble. Plz help
2''lift 31's twin locked & 6.5s
Post Posted: Sun Oct 16, 2011 3:20 am
Leave the out sheath in & just replace the cable.........
Post Posted: Sun Oct 16, 2011 9:44 am
Yeh tryed that but old cable was rusted in down the transfer end so had to can it any way. Thanks for info any ways
Post Posted: Mon Oct 17, 2011 6:49 am
If you do replace the whole thing, tie some strong'ish wire round it before you pull the cable from behind the heater & use it to pull the new one through...
It's best to run em where in the original place's, or you'll get a jumpy speedo or a short life out of the cable...
Post Posted: Wed Oct 21, 2015 7:43 am
I read yesterday where you don't have to drop the cluster, I got my hand up there, but couldn't pull it off.
Does it half turn first, or use more force ?
Replacing the inner cable only, do I just assume the outer is good behind the heater ?.
bye
Vehicle: 98 Jimny
Post Posted: Wed Oct 21, 2015 8:01 am
Can't say much about the outer but I know to pull it off the cluster I just gave it a good yank and a slight twist at the same time. Think like pulling an aerial cable off a TV.
Post Posted: Wed Oct 21, 2015 9:31 am
My TV aerial cable screws on with an "F" connector.
Vehicle: 98 Jimny
Post Posted: Wed Oct 21, 2015 8:23 pm
There's always one..
Users browsing this forum: Google [Bot], phlix and 179 guests
