It is currently Wed Aug 05, 2026 3:00 pm
Post new topic Reply to topic  [ 63 posts ]  Go to page Previous  1, 2, 3  Next
Post Posted: Wed Oct 26, 2011 9:43 am
remember which way round they go, and where all the springs go, can be easy to forget..take photos. it helps.
they are probably self adjusting, so back them off all they way, b4 installing new ones.
And check under wheel cylinder rubbers, cause I bet they leaking too.
Which will stuff ya new shoes fast
And have hand brake off before fitting,
or you wont get drums on.
FRirst pump of brakes will go low, but then they will adjust themselves
Post Posted: Wed Oct 26, 2011 9:48 am
jimny_timmy wrote:
monkey wrote:
Ok i got new brake shoes today....i have not put them on yet cus i have never change shoes before....so where do i start? Is it just a matter of sliding the old one's straight out? Or what? :roll:
Take the wheels off :crazy: :helloo:
Can't i do it with the wheel's on? :roll:
:thefinger:
Vehicle: Suzuki Jimny 2009
Take photos of both sides before you start. Also it is normal for the leading and trailing shoes on each side to be different sizes. I am not sure about Japanese builds but most of the Australian cars that I have worked on were different. Check that out and make sure they go in the correct way.
Post Posted: Wed Oct 26, 2011 9:50 am
Cheer's Chris and Mike.
How do i back them off?
Post Posted: Wed Oct 26, 2011 9:52 am
:thefinger:
Yes we will let you do that because You are special ImageImageImageImage
Post Posted: Wed Oct 26, 2011 9:53 am
Get yourself a workshop manual, has good tips. $10 on ebay.
Post Posted: Wed Oct 26, 2011 9:59 am
never looked inside a jimny drum,
on a sierra it was crank a little ratchet thing back in,
that ran between the shoes,
so shoes dropped away from drums.
Post Posted: Wed Oct 26, 2011 10:04 am
just under the top spring is where my Vits self adjuster was.
It will be obvious how to adjust it back.
The shoes are held in with funny clips,
push and turn to release.
Post Posted: Wed Oct 26, 2011 10:05 am
8) Sounds ease enough...
So that's tomorrow's after noon gone :lol:
PS once you have done this 5 or 6 times,
you will be screaming for discs :))
Post Posted: Wed Oct 26, 2011 10:06 am
Mums comin for lunch,
so I only get half a day in garage
On the cards :wink:
Post Posted: Wed Oct 26, 2011 10:10 am
i wonder if the JML floater kit (minus the axle lengths) would fit the jimny? and if so, do the rear drums have an ABS sensor that needs adapting also?
Post Posted: Wed Oct 26, 2011 10:12 am
I think JML is going to do a full floating rear for Jimny's any way :P
Post Posted: Wed Oct 26, 2011 10:58 am
Make sure you loosen off the handbrake adjustment at the lever before you start. Jimny has self adjusting drums but they clog with mud. You'll need to clean and make sure the ratchet mechanism works freely.
Get ready to swear a bit.
Post Posted: Wed Oct 26, 2011 11:00 am
How long dose it take to change them....i got about 3 hours of sun light after work and that's it....
Post Posted: Wed Oct 26, 2011 11:10 am
15 minutes a side....
Post Posted: Thu Oct 27, 2011 10:50 pm
Help!!!
I got the d-side done no issues there...
Onto the passenger side....i got the old shoes out, got the new one's in, then i put the spring on with the adjuster thing....yeh that's fine...went to put the pin in for the hand brake cable, then the spring with the adjuster come out :x now i can't get it back in :? i have no farking idea if i have done it in the right order, here's how i did it:
-Take old pads out
- sit new pads in place then put the spring with the adjust thing on
-put lower spring on
-put pin in
-now i don't know what to do :(
Now im stuck is that the right order to do it? :(
Post Posted: Thu Oct 27, 2011 10:52 pm
did you screw the adjuster back???
Post Posted: Thu Oct 27, 2011 10:53 pm
yeh so it's all the way in?
Post Posted: Thu Oct 27, 2011 10:54 pm
Told you you'd be tempted to swear
Post Posted: Thu Oct 27, 2011 10:55 pm
The house brick wall copped a hammer last night :lol:
Post Posted: Thu Oct 27, 2011 10:58 pm
yes........
Pull it all apart & start your step's again....
Post Posted: Thu Oct 27, 2011 11:13 pm
Brut force wins every time armsup :lol:
I tried to get the spring in one last time with Brut force and i won 8)
Post Posted: Fri Oct 28, 2011 12:02 am
rear discs are getting closer ;)
Post Posted: Mon Dec 26, 2011 1:03 pm
:helloo:
New pads, different diff center and new wheel bearings...but it's still making noises :? what else could be causing the noises? Drums out of round? :? Really starting to shit me now..... :x
Post Posted: Mon Dec 26, 2011 1:32 pm
don't worry mate, your not the only one who had trouble with these drums..........worst job ever!!!!!
Post Posted: Mon Dec 26, 2011 1:34 pm
Just wild thoughts... Any visible signs of metal to metal contact between shoes and drum, or is the backing plate bent outward a bit and contacting the edge of the drum?
Oh, and how does the handbrake work on a rear disc brake conversion with those Zanfi kits?
Post Posted: Mon Dec 26, 2011 1:38 pm
That was my first thought...but i could not see any paint missing on the backing plate or the out side of the drum...so it must be the pads touching the inside of the drums even with the hand brake off :?
Oh, and i think you would have to have a sierra t-case with a transmission brake( i think that's what there called?) for it to work?
Users browsing this forum: No registered users and 249 guests
