It is currently Sat Jul 18, 2026 10:12 pm
Post Posted: Sun Oct 30, 2011 4:55 am
after a three pin air flow meter cheers for any help guys, also this prob unlikely but anyone got a spare pulley off a G16B water pump?? mine got none :(
Post Posted: Sun Oct 30, 2011 5:27 am
I have this one from the G16A import engine I'm fitting to my Vitara.
It bolted up and lined up perfectly with my G16B water pump.
Both engines had identical water pumps.
I chose to use the pulley from my dead Vitara motor,
as this one has a very slight increase in diametre.
Happy to post from Melbourne, if you don't have any luck local.
Post Posted: Sun Oct 30, 2011 9:32 am
Slightly bigger diameter shouldnt be a problem I wouldn't think, how much bigger is it??
Post Posted: Sun Oct 30, 2011 9:37 am
I will go measure it brb
Post Posted: Sun Oct 30, 2011 9:42 am
My vit one
(rough measurement as its dark out there)
is just over 12cm diameter.
The other is a bit less than 13cm diameter
Post Posted: Sun Oct 30, 2011 9:49 am
Should be fine, how much you want mate??
Post Posted: Sun Oct 30, 2011 9:58 am
just what ever postage costs,
be between $6 and $12
My scales aren't very accurate.
To post I need (in pm)
Name
address
post code.
We have a holiday Tuesday,
so not sure if post office is open Monday.
Post Posted: Sun Oct 30, 2011 10:04 am
pm thanks mate.
Post Posted: Sun Oct 30, 2011 10:10 am
pm thanks mate.
Post Posted: Tue Nov 01, 2011 12:15 am
Ive got a AFM. Not sure if its 3 pin. Ill look when i get home
Post Posted: Tue Nov 01, 2011 12:53 am
Awesome, that would be great. I got the pulley sorted just need an air flow meter now.
Post Posted: Tue Nov 01, 2011 4:35 am
Its 5 pin. Sorry mate
Post Posted: Tue Nov 01, 2011 5:57 am
That's alright hopefully someone has one :)
Post Posted: Wed Nov 02, 2011 7:41 am
bump
