| Author |
Message |
strop
Joined: Wed Jun 08, 2011 12:27 pm Posts: 112 Location: millicent
 Posted: Sun Oct 30, 2011 4:55 am |
after a three pin air flow meter cheers for any help guys, also this prob unlikely but anyone got a spare pulley off a G16B water pump?? mine got none
christover1
 Posted: Sun Oct 30, 2011 5:27 am |
I have this one from the G16A import engine I'm fitting to my Vitara.
It bolted up and lined up perfectly with my G16B water pump.
Both engines had identical water pumps.
I chose to use the pulley from my dead Vitara motor,
as this one has a very slight increase in diametre.
Happy to post from Melbourne, if you don't have any luck local.
strop
 Posted: Sun Oct 30, 2011 9:32 am |
Slightly bigger diameter shouldnt be a problem I wouldn't think, how much bigger is it??
christover1
 Posted: Sun Oct 30, 2011 9:37 am |
strop wrote: Slightly bigger diameter shouldnt be a problem I wouldn't think, how much bigger is it??
I will go measure it brb
christover1
 Posted: Sun Oct 30, 2011 9:42 am |
My vit one
(rough measurement as its dark out there)
is just over 12cm diameter.
The other is a bit less than 13cm diameter
strop
 Posted: Sun Oct 30, 2011 9:49 am |
Should be fine, how much you want mate??
christover1
 Posted: Sun Oct 30, 2011 9:58 am |
strop wrote: Should be fine, how much you want mate??
just what ever postage costs,
be between $6 and $12
My scales aren't very accurate.
To post I need (in pm)
Name
address
post code.
We have a holiday Tuesday,
so not sure if post office is open Monday.
strop
 Posted: Sun Oct 30, 2011 10:04 am |
strop
 Posted: Sun Oct 30, 2011 10:10 am |
canberramav
Joined: Mon Jun 01, 2009 11:30 pm Posts: 643 Location: Canberra
 Posted: Tue Nov 01, 2011 12:15 am |
Ive got a AFM. Not sure if its 3 pin. Ill look when i get home
strop
 Posted: Tue Nov 01, 2011 12:53 am |
Awesome, that would be great. I got the pulley sorted just need an air flow meter now.
canberramav
 Posted: Tue Nov 01, 2011 4:35 am |
strop
 Posted: Tue Nov 01, 2011 5:57 am |
That's alright hopefully someone has one
strop
 Posted: Wed Nov 02, 2011 7:41 am |
