It is currently Sun Nov 08, 2026 12:02 pm
Post Posted: Sun Apr 05, 2009 3:00 am
hey guys
just in the middle of a ruf remodel
anyone got any good pics of custom made shock towers.
ive got some long pin top shocks from the spoa ive just pulled out and need to raise the shock tower approx 4-5 inches to use them.
any help or pics would be tops
cheers andrew.
Post Posted: Sun Apr 05, 2009 3:27 am
Lowrangeoffroad sell Ford towers that you can bolt or weld on. Dunno exact dimensions but I'm sure Sean will answer any questions promptly.
Parts usually arrive within 5-6 days. US$29 each plus shipping.
Dunno how they'll go with pin top shocks. They look like they might need eye tops.. Not sure..
Jas.
Post Posted: Sun Apr 05, 2009 10:53 am
ajsr wrote:
hey guys
cheers andrew.
Are the existing shock towers in the correct position? If so another option could be to cut through the shock tower horizontally and weld in an extension.
Post Posted: Sun Apr 05, 2009 12:41 pm
Damo wrote:
ajsr wrote:
hey guys
cheers andrew.
yeah I thought that myself damo so i removed the stockers as the diff is about 25-30 mm forwards ,but I need the mount about 4-5 inches taller and by the time i streched to stockers that far they were becoming too tall and weak and were hitting the inner guard.
placing them is not the issue a I have removed and rewelded the bumpstop mounts as they missed also. this is a "full" ruf if you like with a chassis extension.
Gwagensteve sent me some great pics of custom ones but I was hoping for an off the shelf fix if possible.
the main pain in the arse is the shocks are pin tops.
cheers andrew
Post Posted: Sun Apr 05, 2009 12:57 pm
Got them from lowrangeoffroad..
But when i went to the 35's, i had to modify them cause they were nearly hitting on the 32's..
So i moved them to the inside.. plenty of room now :)
F&R ARB air lockers, lux diffs, 4 link coil rear,
Post Posted: Sun Apr 05, 2009 1:13 pm
ajsr wrote:
Damo wrote:
ajsr wrote:
hey guys
cheers andrew.
cheers andrew
Steve has got some good ones to suit pin top shock on his buggy. They look pretty easy to make out of flat bar too.
EDIT: Found a pic of Steve's shock towers
Vehicle: Nissan
Post Posted: Sun Apr 05, 2009 10:29 pm
Just done mine But I used hilux towers
It raised the top just over 100mm (4")
http://www.auszookers.com/index.php?nam ... pic&t=4269
:D
Pearce-toff Racing
Post Posted: Mon Dec 05, 2011 11:12 pm
A bit of a grave dig, which I hope AJSR sees.
AJ what shock towers did you end up with? Did you stick with pin top shocks?
Post Posted: Mon Dec 05, 2011 11:25 pm
might as well add mine here:
tons more pics in my build thread: http://www.auszookers.com/index.php?nam ... 54&start=0
Post Posted: Mon Dec 05, 2011 11:39 pm
100x50x3 RHS, Full RUF, spoa.
Post Posted: Mon Dec 05, 2011 11:41 pm
Be gone, SPOA heathens! :lol:
Post Posted: Mon Dec 05, 2011 11:46 pm
:lol:
Vehicle: '96 LWB trayback
Post Posted: Tue Dec 06, 2011 12:04 am
The Ford towers from Lowrange are pretty sweet. They're no use for a pin type shock though, They suit eye-to-eye.
I've ran my zook for several years with the factory front mounts chopped horizontally and extended with 5mm flat bar.
Needed to move them for RUF so grabbed some ford towers. Wish I had done this originally because removing my dodgy extension took days with a 4" grinder.
The ford ones measure:
- 35cm total height from bottom to centre pin, giving you ~200mm over factory mounts.
- 25cm above the top of the chassis rail.
- They stick out 10.5cm from chassis rail towards tyre.
Vehicle: Sj70 tintop
Post Posted: Tue Dec 06, 2011 12:25 am
pretty cheap from low range
these are the universal ones.
Sj70 tintop
Post Posted: Tue Dec 06, 2011 12:26 am
Anyone got pics of something to suit pin top shocks?
Post Posted: Tue Dec 06, 2011 12:28 am
not sure anyone makes them stick mate, you will need new shocks once you put them in so why not just run big eye shocks?
Sj70 tintop
Post Posted: Tue Dec 06, 2011 12:32 am
I already have 10" travel pin top shocks, but am running those with big bumpstop extentions. I want to piss of the bumpstop extensions and to do that will need to raise the shock tower a bit. Steve had some pics of ones he did on his buggy, he's going to try to dig them up tonight.
Post Posted: Tue Dec 06, 2011 12:36 am
sweet, could probably modify some big eye ones to tack pin top shocks, wouldnt be to hard for a good welder/fabber i would guess.
Sj70 tintop
Post Posted: Tue Dec 06, 2011 12:43 am
I could but that would be more effort than just making towers to suit pin top shocks, hence my question.
You Territory blokes aren't real quick are yas :thefinger:
Post Posted: Tue Dec 06, 2011 12:55 am
I modified the ford ones to suit a pin top, shock. will be using these on my lj81.
folded the tabs flat. welded up the hole and re drilled. looks the goods
Post Posted: Tue Dec 06, 2011 1:21 am
i wouldnt buy 10'' pin top shocks so i must be quicker than the average bear
:mrgreen:
Sj70 tintop
Post Posted: Tue Dec 06, 2011 1:28 am
:mrgreen:
yah, no one uses commodore shocks...
Post Posted: Tue Dec 06, 2011 3:32 am
How do the Ford mounts go with N.T spring spacing? How much higher than standard are they?
Vehicle: 75 Cruiser
Post Posted: Tue Dec 06, 2011 4:03 am
mine....made from flat bar.
Post Posted: Tue Dec 06, 2011 4:05 am
That's what i'm talkin about, thanks Steve!
I was wondering if you used something like 5mm flat bar, anything smaller might be a bit flimsy.
Post Posted: Tue Dec 06, 2011 4:37 am
Here's mine, made by Joeblow...
Post Posted: Tue Dec 06, 2011 5:46 am
see what :wink:
universal hoops, I wouldnt use them again too much work. the hoop had to be shortened and then cut and bent and welded back to gether again.
Post Posted: Tue Dec 06, 2011 5:57 am
Thanks AJ, that does look like a fair bit of work. On top of that I am really wary of the tyre clearance to the shock tower of full stuff.
Bootyfab flat bar towers for me by the looks of it!!!
Vehicle: SJ70 1993
Post Posted: Sun Jan 01, 2012 10:20 pm
having shock hoops, does it allow the use for extended shocks or is it so stop it from hitting somewhere during flex?
just wanna know the main benifet of using shock hoops
Lock, Drop and roll
Post Posted: Mon Jan 02, 2012 12:11 am
There's no "benefit" to using shock hoops. They are just an extended shock mount.
In theory, they are quick and easy to bend up if you have a 180 degree die for a bender.
In reality, they are very space inefficient.
They're a hangover from what hilux guys have used for years.
Users browsing this forum: Google [Bot] and 84 guests
