It is currently Tue Oct 20, 2026 6:55 am
Post Posted: Sun Jan 18, 2009 11:10 pm
I have got the instrument cluster out of the zook at the moment and while i've got it out I want to hook up the check engine light. Is the output from the ECU 12v or ground?
EDIT: actually if it's a voltage output it's more likely to be 5v
Post Posted: Mon Jan 19, 2009 12:25 am
the positive from the globe goes to ign source.....the wire from the ecu switches the earth on.
Post Posted: Mon Jan 19, 2009 2:05 am
Is that the same as 8V tbi?
Post Posted: Mon Jan 19, 2009 2:08 am
should be yes.
Post Posted: Mon Jan 19, 2009 1:06 pm
Thanks Joe.
Post Posted: Wed Jan 21, 2009 1:36 am
Since this is sort of related :lol:
What have people done with the check engine light when putting the G16B setup into NT/1L sierra since they dont originally have an engine light in the dash cluster? I still havent hooked one up yet.
Also can I fit the VSS from the G16B into a NT sierra speedo? I know it can be done into a WT but just wondering if it's as simple in a NT speedo. Another thing I havent hooked up yet :oops:
Member of C.O.R 4x4
Post Posted: Wed Jan 21, 2009 1:49 am
cut and glue the check light film from a vit cluster into a spare light hole on the narrow track dash. yes you can hook up a vss as per a wt in your cluster. done this to many a maruti.
Users browsing this forum: Google [Bot] and 303 guests
