It is currently Sun Nov 08, 2026 8:41 am
Vehicle: White A/T Jimny
Post Posted: Wed Dec 28, 2011 9:25 pm
Hi wondering if anyone could giv me a rough idea of what type of reduction i would be looking at it i was to swap out my transfer case for either, 1.3 and 1.0 leafy t-case, or a coily case.
Is the coily transfer case the same as a late model leafy?
thanks
aint nuthin to it but to do it!!! - R.Coleman
Post Posted: Wed Dec 28, 2011 9:31 pm
http://www.auszookers.com/index.php?nam ... 83&start=0
Post Posted: Wed Dec 28, 2011 9:38 pm
yeh already had a look, so i take it the case in an auto jimny is lower than its manual version. would the reduction by swapping my auto case with a sierra 1.3 case even be worth it?
Post Posted: Wed Dec 28, 2011 9:41 pm
should probly mention the purpose is to run 31-32" tyres with gearing similar to factory
Your only running 215's yeh?
EDIT: OK, you will want a sierra transfer for 31's then. I have no idea what the ratio's are in a auto box so you will need to find that out before you can figure out ho much reduction the sierra t-case will give you.
Post Posted: Wed Dec 28, 2011 9:43 pm
about to do body lift and 31s
Post Posted: Wed Dec 28, 2011 9:45 pm
Off topic! But why a body lift for 31's?
Post Posted: Wed Dec 28, 2011 9:50 pm
dont really wanna replace my current suspension setup as its basically new and im happy with the flex. figure i can get 2" cheaper from a body lift than replacing my suspension and adjusting my castor, panards etc.
Just cut more :helloo:
Post Posted: Wed Dec 28, 2011 9:54 pm
yeh plan on doing both
Post Posted: Wed Dec 28, 2011 9:55 pm
:crazy:
Post Posted: Thu Dec 29, 2011 6:31 am
thanks
Coily case is the same ratios as what you already have.
1.3 leafy will only give enough reduction for 235s at best.
IMO a 1.3 wt Sierra transfer with 4.16 gears or an older stock 1.0 transfer would be the way to go. This would give about a 20% reduction in high. The 4.16 would give a good low reduction.
Post Posted: Thu Dec 29, 2011 11:00 am
thanks
thanks, 1.0 seems to be the go.
Post Posted: Thu Dec 29, 2011 8:17 pm
You'll need wide track flanges
Users browsing this forum: No registered users and 202 guests
