It is currently Tue Oct 20, 2026 6:55 am
Post Posted: Fri Jan 30, 2009 12:32 am
ok its time to start to do a RUF
What I know, I think Please correct me if I am wrong
I am getting a full set of 2" rear springs (4 of)
cut off the rear spring mount off chasie and turn it around, weld back on?
cut off the front shackle mount and weld back on app 35mm forward?
Do I need a front tailshaft spacer after the RUF??
also doing front shock hoops
Gaz
I Do Shade Sails & Roller Blinds, ect
Post Posted: Fri Jan 30, 2009 12:37 am
if you are moving the diff forward youll need a spacer, otherwise you dont really need to mover the rear mount back and the front forward but I can see that working well, not too far forward and not massive shackles
Post Posted: Fri Jan 30, 2009 12:42 am
massive shackles
thanks
just running std shackles
doesnt the diff move forward when you do a ruf?
Post Posted: Fri Jan 30, 2009 12:56 am
if you leave the rear mount in the stock spot, if you move it back it wont, depending on how much longer that side of the spring is and haw far you move it
Post Posted: Fri Jan 30, 2009 1:06 am
thanks
when the spring arrive, we will measure it all up
Post Posted: Fri Jan 30, 2009 1:43 am
is there a thread that shows how to do a ruf? looking into this wen i do a spoa
Post Posted: Fri Jan 30, 2009 1:49 am
when I do it I will take lots of pics step by step
I hope!!!!!! :?
Post Posted: Fri Jan 30, 2009 3:21 am
Pop over mate and look at Caspers.
Post Posted: Fri Jan 30, 2009 1:39 pm
x2 its a setup thats proven to work. I plan on doing the same replacing the front spring hangers with the LJ hangers.
Member of C.O.R 4x4
Post Posted: Fri Jan 30, 2009 5:00 pm
We used to use LJ rear mounts on the front of our LJ when doing RUF in the mid 1980's, they are elongated and stick out off the back of the chassis where the front are not. Too hard to find LJ chassis to chop up these days so it's just as easy to make them up. Metal on the LJ ones is a bit thin anyway. These were made up for a RUF, NT to WT conversion.
Post Posted: Sat Jan 31, 2009 1:01 am
Thanks
looks easy to make
got your pm thanks for that
Post Posted: Sat Jan 31, 2009 2:31 am
can you just do the rear springs up front and extended shackles and not move mounting points etc
Users browsing this forum: Google [Bot] and 283 guests
