It is currently Thu Aug 06, 2026 8:21 pm
Post new topic Reply to topic  [ 196 posts ]  Go to page Previous  1, 2, 3, 4, 5 ... 7  Next
Post Posted: Fri Jan 06, 2012 8:25 pm
So the TD shocks are to blame for the terrible ride. Okay, thanks guys, by the sound of it we are all have a pretty stiff ride, so I'll try and find a set of heaps long but softly valved shocks....
Does the common Sierra shock combo fit into the jimny? HiLux/commo?
Here are the slider pics
Post Posted: Fri Jan 06, 2012 8:27 pm
cheers mate, look sorta like mic mounting. that rear mount, is that just plate on the inside rail as well?
always cant figure out how that front bit is mounted with the ring piece... is there a round plate welded in there with a bolt hole in the middle or something?
MY BUILD THREAD HERE!!!!!
Post Posted: Fri Jan 06, 2012 9:04 pm
Just wait 5 mins and i will make a "I made it and fab' post.
Post Posted: Fri Jan 06, 2012 10:55 pm
Sliders are here:
http://www.auszookers.com/index.php?nam ... ic&t=29326
Post Posted: Fri Jan 06, 2012 11:54 pm
cheers blue...... now i have another thing to add to my list
Post Posted: Sat Jan 07, 2012 3:40 am
monkey wrote:
:helloo:
The procomp ES1000 are soft shocks and you can get them to suit 0-5" lift but they DON'T have bump stops built into them. The shocks i got are the 5" ES3000's, they are a fair bit softer than the TD shocks but not as soft as the ES1000. The reason i went for the 3000 series is they have bump stops built into the shocks as do the ES9000's.
You could go for some 4" procomp es1000 then put some bump stop spacer's in to stop the shocks from topping out, but you will need coil retainer's and maybe drop out cones. :P
BTW i was going to post that in your thread but it it's sort of got de-railed :?
http://www.jimnybits.co.uk/shop/jimny/j ... od_15.html
http://www.jimnybits.co.uk/shop/jimny/j ... d_328.html
Dirt cheap to :D
this is tech!
I undid my shocks and my sway bar and flexed it up again, and the shocks were still longer then i needed. So im guessing my bushes are restricting travel more then anything. Is there any special flex bushes you can buy?
Thanks :D
Post Posted: Sat Jan 07, 2012 3:43 am
Bruce's bushes?
Tri-four link?
Post Posted: Sat Jan 07, 2012 4:12 am
simpler the better, so 3link is my last resort.....
yeah, will pm bruce now....
Post Posted: Sat Jan 07, 2012 4:55 am
Jimny are 3 link already? :?
Post Posted: Sat Jan 07, 2012 4:57 am
Pan hard......
Post Posted: Sat Jan 07, 2012 5:09 am
Hazar
Post Posted: Sat Jan 07, 2012 5:18 am
steak_knife wrote:
Pan hard......
my bad I was including the panhard rod :crazy:
Post Posted: Sat Jan 07, 2012 5:19 am
That's 4....
Where does the sump go???
Post Posted: Sat Jan 07, 2012 5:50 am
though the pan hard... obviously.
Post Posted: Sat Jan 07, 2012 6:12 am
FAIL!
The pan hard runs in front of the axle on the pic I posted. I would not put the link there, possibly offset under/outside of the chassis....
Post Posted: Sat Jan 07, 2012 6:38 am
million dollar question..... how hard are you going to push this thing? :wink:
could be a better/cheaper option doing a 3 link front using a WT housing with Cromo's than trying to upgrade the jimny diff?
Post Posted: Sat Jan 07, 2012 6:48 am
http://translate.google.com.au/translat ... ls%3Den-us
if ya want the ultimate in flex for jimnys try the Japs websites
:helloo:
http://translate.googleusercontent.com/ ... maZOUBO7MQ
http://translate.googleusercontent.com/ ... N4rNCc9Glg
:P
edit: donno why pics link wont work.... just clik on them :crazy:
Post Posted: Sat Jan 07, 2012 8:29 am
Custom is easier/cheaper/how you want it.
Post Posted: Sat Jan 07, 2012 9:07 am
Hmm, a crude 3link panhard might be the best option so far.... That's Bert, 285000yen, sounds like allot!
Post Posted: Sat Jan 07, 2012 9:20 am
We should do two at once! ;)
Post Posted: Sat Jan 07, 2012 9:29 am
I thought about it but I'm pretty sure a Jimmy diff is the same width as a Coily, so chromo's would have to be custom anyway, and a Jimmy runs the tie rod behind the diff with a high pin center. I haven't jumped on a 3link calculator yet, but I'm hoping I can build 2 new lower links and attach them to stock positions, then build one bracket on the chassis and mount on the diff and be done with it.
As for how hard, Rope Rd, secret creek, steps, QLD gate, this new secret track that would have stopped my old lwb ;)
Post Posted: Sat Jan 07, 2012 9:32 am
Have you seen Jezza's thing on Facebook about Rope Rd? For Australia Day.
Post Posted: Sat Jan 07, 2012 9:34 am
I never say it was cheap :P
Post Posted: Sat Jan 07, 2012 9:35 am
run vitara diffs =) 8)
A 3 link f&r would be simple! Make up some custom arms and keep your lower diff mounts stock if needed to be reversed one day.
ifs diff with hilux leafs ftw.
Post Posted: Sat Jan 07, 2012 9:36 am
Joeblow is bout to finish some big ass cvs and axles for jimnys soon :wink:
http://auszookers.com/index.php?name=Fo ... ic&t=26301
Post Posted: Sat Jan 07, 2012 9:38 am
8) something along the lines of that blue tin top coily "FL33XY" with the brush bars & bushwackers???
Post Posted: Sat Jan 07, 2012 9:42 am
Yeah but you want something off the shelf, fast to replace. Not "in progress" for months on end
It's not going to be done by then :lol: and I think Im gunna throw a BBQ, or maybe bum a lift :-)
Yeah, Reversable and an Aussie first i think....
I know ;)
Users browsing this forum: BZOOK and 789 guests
