It is currently Mon Nov 09, 2026 7:36 pm
Post Posted: Sat Jan 07, 2012 6:36 am
Hey
I have a suzuki sierra JX 91 model and I see that my steering damper is old and stuffed.
What is the cheapest place to buy a new damper for my car and where. Also what are some good brands?
Cheers :)
Post Posted: Sat Jan 07, 2012 6:45 am
Anything bigger than the std one, I'm not a fan of the RTC's but others love em.
I've fitted the ultima's of ebay & not had a drama
Post Posted: Sat Jan 07, 2012 6:47 am
I have used Gabriel and Old Man Emu (ARB) dampers on Sierras,
very happy with both.
This was a while ago, may be more options now.
Post Posted: Sat Jan 07, 2012 6:49 am
Ok i'll check them out.
thanks guys :)
Post Posted: Sat Jan 07, 2012 8:44 am
Standard one works fine if you wheel bearings, castor etc etc are all up to stratch.
Post Posted: Sat Jan 07, 2012 8:50 am
your cheapest ever option is to just take the old one off and run it without one... mine steered so much better once i took my shagged one off, and there was zero difference in bump steer.
Vehicle: Coil Sierra
Post Posted: Sat Jan 07, 2012 10:56 am
Paid 165 for a tough dog rtc from OL. Seen them on ebay for 220. Didnt make a huge difference but keeps it from wandering.
Post Posted: Sat Jan 07, 2012 11:14 am
And there's the right answer.
Post Posted: Sat Jan 07, 2012 9:01 pm
sweet i'll give it a chop
thanks
Post Posted: Sat Jan 07, 2012 9:05 pm
I run with out one. I don't find much different and I'm running 33s
Post Posted: Sat Jan 07, 2012 9:31 pm
Do you have p/s????
I don't run one either, but I've a vit box.
Post Posted: Sat Jan 07, 2012 9:33 pm
Cause yours was fucked, Suzuki didn't fit em for look's...
Mr G Please explain in less than 100 word's!!!
Post Posted: Sat Jan 07, 2012 10:46 pm
steak_knife wrote:
Do you have p/s????
I do have p/s running a jimmy box
Post Posted: Sat Jan 07, 2012 10:51 pm
do you drive it at 100kph???
Get a wobble if you do??
Post Posted: Sat Jan 07, 2012 11:02 pm
Yeh it sits on 100 fine with no wobble. I can even let go of the streeing wheel and go straight with out pulling to one side
Post Posted: Sat Jan 07, 2012 11:06 pm
lol =)
yeah mine was buggered so it steered much nicer... i dont have power steer to reduce bump steer, i just have arms of steel (lol). I do have lots of caster though so no wobbles.
Post Posted: Sat Jan 07, 2012 11:07 pm
Dampener's got nothing to do with that tho...
Even with a Jimny box no wobble??? :lol:
Post Posted: Sat Jan 07, 2012 11:08 pm
My Sierra needed a steering damper,
untill fitting power steering.
Then it was fine.
I'm guessing power steering has a type of fluid damper effect.
Post Posted: Sat Jan 07, 2012 11:10 pm
I just took my Suzuki one off. Its heaps better!
(31's, no power steer)
Post Posted: Sat Jan 07, 2012 11:14 pm
alien wrote:
lol =)
Spring over, what Diff's??? Still W/t???
Post Posted: Sat Jan 07, 2012 11:18 pm
If you have dramas without a steering dampener then you having issues elsewhere like poor castor, worn wheel bearings, worn tie rod ends, or even loose U bolts.
I've run mine with the 34's and no steering dampener and only ever rarely get bump steer on the nastiest of pot holes and I know my tie rod ends aren't the best. With a stock dampener that masks that problem enough. Any more need than the stock dampener and you have problems that need attention. Believe me, I used to run a RTC steering dampener and have horrible wheel bearings etc. Once the RTC broke (and it will) my car was dangerous to drive. I attended to the problems in the front end and fitted some Chromo's and a locker at the same time and drove for quite some time after that without a dampener at all. Only just recently fitted a stock one, but didn't really need it.
Post Posted: Sat Jan 07, 2012 11:26 pm
steak_knife wrote:
alien wrote:
lol =)
SPOA, lux leaves, WT diffs, High Steer - the high steer is a little longer than the factory arm too, so more leverage there making the steering lighter (marginal).
Post Posted: Sat Jan 07, 2012 11:27 pm
Yeh I thought about that when I sent it lol
No wobble so far :)
Post Posted: Sat Jan 07, 2012 11:29 pm
alien wrote:
steak_knife wrote:
alien wrote:
lol =)
you don't count in this then, as the Op is Std'ish... :lol:
Post Posted: Sat Jan 07, 2012 11:39 pm
6-10mm more on a steering arm is hardly going to affect bump steer though, and a 31" tyre is a lot of leverage on the steering to induce bump steer compared to a 26" tyre.
caster is irrelevant because as pointed out above - if you've got the wobbles then something else is broken and just being masked.
IMO the OP should try running without for a day or so and if it feels ok then just run with it... its free and easy.
Post Posted: Sat Jan 07, 2012 11:44 pm
If it's already buggered tho, he'd be used to driving it that way, so he won't notice the difference, if he fit's a new one he will notice a HUGE friggin difference :D
Post Posted: Sun Jan 08, 2012 6:16 am
Everyone that keeps saying bumpsteer and doesnt seem to understand what bumpsteer means stop saying bumpsteer
a damper wont do anything for REAL bumpsteer, only making the draglink flatter will
For everyone says you dont need it, you might not need it but its not he answer, mine only wobbled once I fitted power steer and took the damper off, a calmini damper on the diff (I agree the stock setup is a fairly stupid design) was the only thing that fixed it without altering my suspension to something I didnt want to have
Post Posted: Sun Jan 08, 2012 9:33 am
http://en.wikipedia.org/wiki/Bump_steer
huh go figure - i always thought bump steer was the effect of a rut/rock/obstacle hitting the tyre and trying to rip the steering wheel out of your hands. (ie: a bump causing the car to steer).
so what's what we're talking about really called???
Post Posted: Sun Jan 08, 2012 9:44 am
Wobble..... :lol:
Post Posted: Sun Jan 08, 2012 9:53 am
steak_knife wrote:
Wobble..... :lol:
NAAAAHHH it is Death Wobble. :roll:
Users browsing this forum: No registered users and 99 guests
