It is currently Fri Jul 24, 2026 2:47 am
Post new topic Reply to topic  [ 58 posts ]  Go to page 1, 2  Next
Post Posted: Sun Feb 01, 2009 4:42 pm
Was bored today, so was mucking around with my zook checking its flex. We need a flex thread so post up you best flex, dont forget to add spec's for the "tech".
Mine is tin top SWB mods are:
2" body lift
spoa on 80 diffs
2" exstended shackels
stock springs
37" wranglers
80 series power steer box
jimbo
 Profile YIM
Post Posted: Sun Feb 01, 2009 6:04 pm
You win i wont post
Post Posted: Sun Feb 01, 2009 6:42 pm
LWB WT maruti
- 2" rear springs
- suzuki carry rear springs up front(ruf)
- 32" muddies
Member of C.O.R 4x4
Post Posted: Sun Feb 01, 2009 8:44 pm
Cheating! No shox!
Post Posted: Sun Feb 01, 2009 8:48 pm
http://img217.imageshack.us/my.php?imag ... 025qj2.jpg
91 Vitara jlx swb with "3inch suspention lift" 2 inch body lift and 30 inch muddies.
for some reason i cant get the pic to load :0
[img]http://img295.imageshack.us/img295/7474/plate
Post Posted: Sun Feb 01, 2009 9:05 pm
Lux fronts in rear, standard zook fronts, leaves removed, and clamps opened up, climax drop shackles all round, custom front shock hoops, inboarded rear shocks, rancho 9000 all round. 1308 RTI
And when i finshed the lux conversion.. with 32's.. and no shocks or bumpstops!
F&R ARB air lockers, lux diffs, 4 link coil rear,
Post Posted: Sun Feb 01, 2009 10:31 pm
mike_nofx wrote:
Cheating! No shox!
still building no shocks yet will be using rancho rs 9000's
 Profile YIM
Post Posted: Sun Feb 01, 2009 10:34 pm
there you go
 Profile YIM
Post Posted: Sun Feb 01, 2009 11:35 pm
thanks jimbo
Post Posted: Sun Feb 01, 2009 11:39 pm
atari4x4, SV420, 3"calmini, 3"bl, 31" MT/R's
Post Posted: Mon Feb 02, 2009 12:59 am
Half Ruf, extended shackles, extended bumpstops, extended brakelines, 33" tyres. Gabriel hilux/commodore shocks, 2" BL.
Post Posted: Mon Feb 02, 2009 1:06 am
wardy wrote:
http://img217.imageshack.us/my.php?image=phonepiks025qj2.jpg
i was down in toronto the other week and i think i saw your car at the coles there. i was admiring it haha
Post Posted: Mon Feb 02, 2009 1:40 am
Pretty stock LJ50 just has Stockman housings and "hand me down" gas shocks off a Daihatsu F50. Standard shackles with worn rubber bushes. Bit of an anticlimax after the Sierras I know.
Post Posted: Mon Feb 02, 2009 2:16 am
thats no anti climax that thing would make almost 1000 on an rti ramp if that ramp is at the right angle and that is a figure some tough trucks dont make
Post Posted: Mon Feb 02, 2009 3:46 am
Standard flat springs front back with SPOA. 1000 RTI without the pins being pulled for the 3/4 elliptic rear. Pan-hard bar fitted on the front and anti wrap bar on the rear. Running 3 leaf packs.
Extended front shock towers, inverted rears.
Post Posted: Mon Feb 02, 2009 3:47 am
Haha yep thats me. There is a couple other nice vitaras in the car park there most days.
Post Posted: Mon Feb 02, 2009 3:55 am
my coily 2 inch suspension 2 inch body and removed front sway bar, 30 inch tiers
cheers scott
black coily, 30 inch tyers, 2 inch suspention, 2 i
Post Posted: Mon Feb 02, 2009 4:36 am
"SPUA"
2"Body
Pretty much 2" supension lift including double size shackles
Front: Ruf :30mm diff forward
Rear:Corolla/mazda323wagrears : 15mm rearward
Commo/lux shocks.
33'x12.5 +28rims
Post Posted: Mon Feb 02, 2009 9:40 pm
I have to drive it up a ramp at an angle to prevent the rear wheel running up the ramp. In the ramp pic (taken on the ramp at Cityview 4x4 park) I stopped because the rear was on the bottom. If I take it on the angle the rear wheel goes about 300mm past the bottom. LJ50's have narrow spring spacings and housings are 100mm wider than stock also LJ50 rear shocks are inboard of chassis rails. Also the wheelbase is only 76".
Post Posted: Mon Feb 02, 2009 10:07 pm
Thats pretty bloody impresive mate.. Good work!!!
Post Posted: Tue Feb 03, 2009 12:41 am
what i meant was the ramps for rti are either 23 or 30 degrees from the ground not saying anything bout your driving
Post Posted: Tue Feb 03, 2009 2:02 am
is it still classed as flex if the car is unable to be driven?
Post Posted: Tue Feb 03, 2009 2:23 am
Zook-fan, I hope you don't think I took offence at your reply, I took it as a compliment, thanks. Don't know the ramp angle I think it belonged to "Complete 4x4 Centre" Not as impressive as yours or Zookernator's but in QLD the fun police are quick to pounce on anything sprung over or with drop shackles or 35"s for that matter (must be fun though)
Post Posted: Tue Feb 03, 2009 4:08 am
werent there that day :/ i was surprised when i saw it cause the number plate looked familiar. and im from the gold coast
Post Posted: Wed Feb 04, 2009 12:32 am
Grover back in 2005. LJ 50 chassis LJ 80 width custom diff's, 4play leafover on stock springs, 4play extending shackles, Warn Black Dimond shocks on 4play mounts, 2" body lift and 35" tyres... :lol:
Post Posted: Wed Feb 04, 2009 3:47 pm
1997 coily
Custom tube control arms (no more bending)
Jimny Upper Coil mounts and custom coil seats (front)
Stupid Stiff as hell Poly bushes
Pro Comp Shocks that are to SHORT
NO body lift
i think it ended up about 4.5 inch lift (Honda Crv 50mm lifted rear springs alround lol)
Extended Braided Brake lines
Exntended Panhards
30*9.5 tyres
should travel better when i get some nice rubber bushes for the front and some longer shocks, maybe even softer springs for the front iiii dunno.
sam
Post Posted: Wed Feb 04, 2009 10:27 pm
Poly bushes are for sure the enemy of travel in a 3 link. You can get ones with holes in them for Nissans and Rovers. Dunno about Zooks though.
Post Posted: Wed Feb 04, 2009 11:18 pm
As a comparison.
This is my 96 SJ80.
Stock arms, stock worn rubber bushes. Sway Bar removed, about a 40mm lift. Front lower strut mounts chopped off and rotated 90 degrees and remounted slightly higher on top of axle housing strengthening.
With the shocks unbolted (i.e. it needs longer shocks) i can get another brick out of it without to many worries and i am sure cheating with tyre pressures would get a fraction more.
Post Posted: Thu Feb 05, 2009 1:36 am
eh kenn....is that geremy in the background playing with a gadget? 8O
Post Posted: Thu Feb 05, 2009 4:13 am
Why i believe it is Gadget Man..Must be working out the most direct route to the nearest Latte or something....
Users browsing this forum: Google [Bot], Google Adsense [Bot] and 339 guests
