It is currently Tue Oct 20, 2026 2:10 pm
lesspostingmorewheeling
Post Posted: Mon Feb 02, 2009 8:09 pm
i'm looking at moving my front shackle mounts forward so i can use shorter shackles but i was wondering will this give me more or less travel and how far should the mounts be moved foward?
Mike
Vehicle: 75 Cruiser
Post Posted: Mon Feb 02, 2009 9:23 pm
carefull with the quality of welding or royce and joe will cane your arse :wink:
Post Posted: Mon Feb 02, 2009 9:41 pm
don't worry it won't be me welding it although i do think my gassless mig skills are upto the task :wink:
Vehicle: 75 Cruiser
Post Posted: Mon Feb 02, 2009 9:42 pm
we want to see sample welding photos 8)
Post Posted: Mon Feb 02, 2009 9:45 pm
i will post welding pics if someone gives me the infomation i need
Post Posted: Mon Feb 02, 2009 10:12 pm
Mike
Im about to do this myself.. so i'll be watching this thread closely!! :wink:
F&R ARB air lockers, lux diffs, 4 link coil rear,
Post Posted: Mon Feb 02, 2009 10:24 pm
zookernator wrote:
Mike
what i have to do it first so you can learn from my mistakes?
Post Posted: Mon Feb 02, 2009 10:29 pm
Next you'll be telling me that Sikaflex is not appropriate for this application!
Post Posted: Mon Feb 02, 2009 10:36 pm
Mike wrote:
zookernator wrote:
Mike
hahahaha.. we can share!! :wink:
Post Posted: Mon Feb 02, 2009 10:54 pm
work out how long the spring is along the leaf, work out how long you want your shackle and whats the max angle you want the shackle to be under (I think about 60degrees they can invert)
then some maths to work it out will tell you how far apart the mounts need to be, simple
or just figure how much longer than stock they are and move it that much, doubt youll lose any flex
Post Posted: Mon Feb 02, 2009 11:00 pm
wouldn't i loose down travel with shorter shackles and the mounts moved forward?
Post Posted: Tue Feb 03, 2009 12:43 am
possible but the spring might have more flex in it if alowed to drop more freely and for how it was designed with smaller shackles. you will also loose a bit of hieght but that is obvious
Post Posted: Tue Feb 03, 2009 1:08 am
unless you can make the shackle point at the diff on full droop then I very much doubt it
Post Posted: Tue Feb 03, 2009 1:33 am
so how much further forward should the front mounts be then?
Post Posted: Tue Feb 03, 2009 1:43 am
Post Posted: Tue Feb 03, 2009 1:57 am
haha what is the maths involved?
what i meant to ask was what setups have people used before that worked well?
Post Posted: Tue Feb 03, 2009 2:01 am
I think 3" is the common amount
Post Posted: Tue Feb 03, 2009 2:26 am
Since you're using a rear spring, wouldnt you just measure how far apart the spring and shackle hangers are in the rear and make the front the same?
Post Posted: Tue Feb 03, 2009 2:49 am
but wouldn't that make the front flex like the rear does standard?
Post Posted: Tue Feb 03, 2009 3:07 am
yeah but with more weight over it
Post Posted: Tue Feb 03, 2009 3:52 am
how is that benefictial? are there any benefits of having a chassis extention over having longer shackles?
Post Posted: Tue Feb 03, 2009 11:52 am
The distance that these are apart isn't really what is affecting wheel travel. It's the spring rate and the fact you've got a longer main leaf.
Usually you will get droop with longer shackles. The benefit of going with a chassis extension is that you can keep the stock shackles. Some may not see it as a benefit, YMMV.
Post Posted: Tue Feb 03, 2009 9:53 pm
so really chassis extentions only benefit ride quailty and on road performance?
Post Posted: Wed Feb 04, 2009 12:36 am
shorter shackles are a shit load more stable, better approach angle too
Post Posted: Thu Feb 05, 2009 2:36 am
what about getting one of these: http://www.rocky-road.com/ruf.html
it wouldnt cost much to make and once you've made one you can put up the dimensions sto show us all how to do it :D
Post Posted: Thu Feb 05, 2009 3:10 am
that kit looks good but i think i'm gonna go another way
Post Posted: Thu Feb 05, 2009 11:47 am
hehe, your not keeping secrets are you mike :wink:
Post Posted: Thu Feb 05, 2009 4:20 pm
haha your just jealous that your not the only person who knows about it anymore
Post Posted: Thu Feb 05, 2009 5:06 pm
:thefinger: hahaha
Post Posted: Thu Feb 05, 2009 6:09 pm
zookernator wrote:
:thefinger: hahaha
haha to make you feel special i'll tell you later what i find out today
Users browsing this forum: Google Adsense [Bot] and 181 guests
