It is currently Thu Aug 06, 2026 5:00 pm
Post new topic Reply to topic  [ 196 posts ]  Go to page Previous  1, 2, 3, 4, 5, 6, 7  Next
Vehicle: Suzuki Jimny 2010
Post Posted: Sat Jan 14, 2012 6:16 am
8O Holy Toledo Batman!
Post Posted: Sat Jan 14, 2012 6:40 am
yeah but only short by about 50mm.... can't wait to get it built... maybe i can fit a travel ramp into the build plan :lol:
30deg ramp! ;)
Post Posted: Sat Jan 14, 2012 1:21 pm
steak_knife wrote:
8O
Indeed!
Post Posted: Sat Jan 14, 2012 1:45 pm
Looks like he cocked it's leg cause the puddle on the ground :lol:
Vehicle: Jimny
Post Posted: Sat Jan 14, 2012 10:11 pm
Did you unbolt the top of the radious arms or something? That's intense
DONT BUY A GQ! zooks are better. i have both :)
Post Posted: Sat Jan 14, 2012 10:17 pm
Jesus! :lol:
Post Posted: Sun Jan 15, 2012 1:29 am
YES TIM?
Post Posted: Sun Jan 15, 2012 1:36 am
he's unbolted the front bolt in the RHS radius arm at the diff end.
in that picture above, you can see the front end of the RHS radius hanging lower than the diff.
Post Posted: Sun Jan 15, 2012 3:21 am
X2
Post Posted: Sun Jan 15, 2012 3:22 am
appsie wrote:
YES TIM?
OMG
Post Posted: Mon Jan 16, 2012 9:32 am
I'm looking forward to watching this progression. Will be nice to see something quite different. All sounds pretty involved and way past anything I'd attempt but that travel with the bolt removed looks worth investigating.
Post Posted: Mon Jan 16, 2012 9:55 am
And the little tyres make it look insane haha. I'm keen to see it wheeling!
Post Posted: Mon Jan 16, 2012 12:27 pm
:| :D
Assuming a 3 link setup removes the need for a panhard too?
Post Posted: Mon Jan 16, 2012 4:55 pm
Not an A frame type 3link, more like the picture I posted earlier.
Geepers, with all this anticipation I better deliver :lol:
Post Posted: Mon Jan 16, 2012 5:28 pm
Hazar
Radius arm 3link to 3link + panhard.
Yeah you should do it before the 29th.
Post Posted: Mon Jan 16, 2012 6:17 pm
Whats on the 29th?
Vehicle: Work van
Post Posted: Mon Jan 16, 2012 6:18 pm
Whats on the 29th?
Rope road will most likely be the 28th :helloo:
Swb softie spoa cromo front -50 beadlocks 6.5s :D
Post Posted: Mon Jan 16, 2012 7:44 pm
Need's more black.... :wink:
Post Posted: Mon Jan 16, 2012 7:54 pm
I think you can safely say longer brake lines will be needed ;)
Post Posted: Mon Jan 16, 2012 8:42 pm
I think hover boards strapped to the chassis is the better option..
Post Posted: Mon Jan 16, 2012 9:23 pm
have you considerd x-linking it???? lock it for road use
Post Posted: Mon Jan 16, 2012 9:25 pm
jonno_racing wrote:
have you considered x-linking it???? lock it for road use
I think he will want it easily reversable.
Not much room for an xlink under there..
All he needs is 6 arms and 4 mounts bit'o'weld and he has a simple 3 link front and rear.
Post Posted: Mon Jan 16, 2012 9:38 pm
Yeah Joshy I think I can be your nav ;)
And tim, bam, your right! X-links might work a heap better with heavier cars as there is still 3bushes per arm to flex through....
Post Posted: Mon Jan 16, 2012 9:41 pm
Keep an eye one your front shaft spline,
Get a new rear shaft(is it cv style?),
New brakelines?
pissorf the vac hubs and lines
Post Posted: Mon Jan 16, 2012 9:56 pm
With a Sierra case you put two front WT drive shafts in, my rear one will have to be shortened a bit for dig tho.... So NO CVs in my car :D and yeah heaps longer brake lines and maybe the hand brake cable will be fine, not sure yet.... And I might have to put man hubs on for the 1.3CV ;)
Post Posted: Mon Jan 16, 2012 10:01 pm
I think you will have to put man hubs with the wt t-case any way....
Post Posted: Mon Jan 16, 2012 10:05 pm
If you can't wire up the hub switch your probably retarded..... But none the less I'll probe stick man hubs on....
Post Posted: Mon Jan 16, 2012 10:18 pm
Where has this 2 x WT front shafts come from? I keep seeing it repeated by various people and has obviously started from someone saying it once (I hope I didn't say it by mistake somewhere).
Only need one which replaces the Rear Jimny shaft. The only other shaft you'll need is a WT Jack (intermediate shaft).
Jimny front shaft stays.
Post Posted: Mon Jan 16, 2012 11:26 pm
Have you seen how many wires there are on a new VVT t-case? 8O
Also what would you wire it up to? a switch? :?
Post Posted: Tue Jan 17, 2012 12:32 am
Well I heard that from monley. Okay, jack shaft and front shaft it is.
And go through your FSM and you should find a vac hub selector switch..... Then put a switch in the cab and your done :D
I think to fit 1.3 CVs you will need man hubs....
Users browsing this forum: Google [Bot] and 679 guests
