It is currently Mon Nov 09, 2026 12:27 am
Post Posted: Fri Jan 20, 2012 12:41 pm
Hey guys, I have a '99 G13bb jimny. It over heats a bit and is quiet annoying.... The things i've read, I don't have a heater, so I'm guessing my heater hose was routed back on itself to stop the heater core from leaking, this I'm guessing would also be why I can hear a boiling sound when I have my fan running (AC or not). I have flushed the rad, replaced the thermostat with a new one and gotten a new rad cap. I read somewhere that when you double the heater hose back on itself it makes it run a bit hotter, because it stops a bit of flow through the head. And that jimny's have a habit of keeping air pocket in the system. It only does it when I'm 4wd'n, or working hard like a beach.... And by over heating, I mean I have to stop the motor and run the thermo fan because I have it in the red, at the top, 4/4..... It's done 199xxxkms.
Am I up for a new heater core?
Thanks guys :D
Post Posted: Fri Jan 20, 2012 12:47 pm
checked the viscous fan clutch or is it just running a thermo fan?
might pay to get the radiator rodded if the tanks still look good.
Post Posted: Fri Jan 20, 2012 1:02 pm
Jims have a engine fan clutch/viscous, and a thermo on the front for the a/c.
I have a good heater core here. Free if you need it with free post. Its out of the black jim, BUT, it sounds like there's more to it. I didnt run my heater core in my last sierra as it leaked. Temp was fine.
Post Posted: Fri Jan 20, 2012 1:58 pm
buy an IR gun and check the temp all over the block, thermostat housing, lower and upper rad hoses etc...
might be a dodgy thermostat, or perhaps the gauge is just reading wrong.
Post Posted: Fri Jan 20, 2012 6:29 pm
Thanks guys :D
Mine did that, I think it's just a bad design as I couldn't find anything wrong.....
X20 on the clutch fan...
Post Posted: Fri Jan 20, 2012 7:05 pm
Okay, I'll go buy a fan clutch.
Can I just say to everyone that since buying the car from bluesuzy, Tim has been more then helpful, and like I'm sure you can read, is willing to go to extreme lengths and measures to make sure he isn't ripping anyone off. I wouldn't worry about it tim, it's a car, they break, I probably broke it.
Thanks guys will report back with if it worked or not.
Post Posted: Fri Jan 20, 2012 7:09 pm
You got a dud..... :roll:
Post Posted: Fri Jan 20, 2012 7:16 pm
have a look at how the heater has been bypassed, it looks in the manual they dont run a tap so its likely they need that coolant circuit to be always flowing, if its blocked it could be causing a hot spot and localised boiling
once its hot will it idle itself back to temp?
Post Posted: Fri Jan 20, 2012 9:30 pm
have a look at the viscous clutch & see if it's able to be serviced with the Toyota Silicone Oil like what Christover did to his Vitara one... might save you a bit coinage. :wink:
http://auszookers.com/index.php?name=Fo ... ic&t=28644
Post Posted: Fri Jan 20, 2012 10:38 pm
Always the way though. Fine on road, but not off. :(
Vehicle: 99 Dirty Green Jimny
Post Posted: Fri Jan 20, 2012 11:59 pm
I had this problem a few months back, same model/km's.. there was some foam insulating stuff that had degraded then fallen down in front of the fan. Was only blocking airflow a tiny bit, but caused overheating / boiling coolant on sand.
I guess you checked that, just posting in case someone else has that problem.
Post Posted: Sat Jan 21, 2012 4:23 am
I'll try a viscous clutch tomorrow. And yeah, my rad is pretty clean and tidy, I might grab the air compressor and blow it out tomorrow tho....
Thanks guys :D
Post Posted: Sun Jan 22, 2012 7:57 am
Mine also overheats on warm days with medium to heavy engine load. I've flushed that rad, which helped a bit, but it still gets hot.
Clutch fan is operating fine, as is the thermo. My heater is also bearly working, but it isn't bypassed or leaking.
Might get a new thermostat, and if that doesn't work, I think I'll drop it at a radiator/cooling system place for diagnosis.
Post Posted: Sun Jan 22, 2012 9:42 am
Hmm, but any of my other 4wds never got hot, even 40deg and wheeling big rock real slow like..... Getting hot isn't even an option for me, that is just crap.
How do i check that it's my fan playing up? Is there some way to check it?
Post Posted: Tue Jan 24, 2012 7:41 am
you keen on grabbing it when its up to temp and speed? :lol:
If its not working you can always take it out, jam a couple of screws to lock it and put it back in and have it run as a normal engine fan
Post Posted: Tue Jan 24, 2012 11:44 am
Haha, will buy a new clutch fan when I get a chance.
And do all te other billion jobs I have :lol: :?
Post Posted: Mon Jan 30, 2012 5:25 pm
so it's not meant to look like this?
i ended up going to Toyota and getting some fan clutch jelly. Because suzuki wanted $290 imported from japan.....
Post Posted: Mon Jan 30, 2012 9:59 pm
my fan oil was toyota, off ebay, delivered for $19
Post Posted: Mon Jan 30, 2012 10:37 pm
That looks abit non oily :?
Post Posted: Tue Jan 31, 2012 5:38 am
Yeah, it took about 25ml's of jelly to bring it back up, I wasn't sure how much was meant to go in but I figured if it hydro locks it will work even better haha
Post Posted: Tue Jan 31, 2012 2:15 pm
did it fix the issue?
Post Posted: Wed Feb 01, 2012 2:16 pm
So far so good, the real test will be Stockton on Sunday....
Vehicle: Suzuki Jimny 2010
Post Posted: Wed Feb 01, 2012 2:20 pm
yaayyyyy wet beach run lol
Post Posted: Mon Feb 06, 2012 6:15 pm
How did it go on the beach?
Post Posted: Mon Feb 06, 2012 7:47 pm
Didn't go on the beach in the end, night shift makes you not see a busy wife all week... Will try to go for a wheel soon.
Although I did tow a heavy trailer with 235s and stock gearing on a 35° day and the needle didn't move a mill... Pretty happy :-)
Post Posted: Mon Feb 06, 2012 10:25 pm
That sounds promising! :D
Post Posted: Thu Feb 23, 2012 3:07 pm
Well guys it's been a few weeks now and I've been driving with the AC cranked, towing trailers, loaded up, drifting, doing multiple hours solidly cruising. It's awesome
yess!!
So the differences, it now doesn't rise or lower the temp at all, the engine heats up quickly, and the AC works a fair bit better then before.
Havn't been wheeling yet, but when I do I will report back.
Post Posted: Thu Feb 23, 2012 6:55 pm
Let's go Sunday :D
Post Posted: Fri Feb 24, 2012 3:54 am
Haha, I'm working 12days straight. Wish I had time to scratch myself...
And my ORA should be here within the next month, and that's kinda needed for wheel with 235s.... Friggen poor effort on suzuki's behalf with the lowrange department....
Users browsing this forum: No registered users and 100 guests
