It is currently Mon Nov 09, 2026 2:49 am
Vehicle: LPG 1.6 Sierra
Post Posted: Sun Feb 05, 2012 5:13 pm
Wow! The forum has had a makeover since my last visit... looks the goods 8)
Anyhows - I have a rust spot on both sides of my front clip near the headlights.
Not the best pick, but you can see the rust is bubbling through on the back. What's the best way to stop this in it's tracks?
Post Posted: Sun Feb 05, 2012 6:11 pm
Im not 100% sure what the profesionals would say but i would get a wire wheel for a drill and hit it with that untill its back to nice clean metal and then paint rust kill or simmilar on there. it shouldnt matter if there is a hole there no one is going to see it.
Sierra, 32's, Airlocked, 6.5'd, hopefully ruf soon
Post Posted: Sun Feb 05, 2012 6:12 pm
id try and give it a sand blast , check the weld , seam seal and paint
Post Posted: Sun Feb 05, 2012 8:22 pm
Its double skinned and the rust is starting between the two sheets. Best to cut it out, dunno how you would stop it from the outside.
Lil Foot!
Post Posted: Sun Feb 05, 2012 8:31 pm
Penitrol
bye
Post Posted: Sun Feb 05, 2012 8:51 pm
bingo penitrol is the stuff or por-15 i think its called spray that and it seeps in between the double panels and i think it can be mix with paint but check first i maybe wrong
josh AKA Bazook
Post Posted: Mon Feb 06, 2012 8:45 am
In the day, they use to get a hole saw and just cut it out. No steel no need to worry. ;)
Post Posted: Mon Feb 06, 2012 2:08 pm
That's what I did :wink:
Lil Foot!
Post Posted: Mon Feb 06, 2012 9:22 pm
I am a penal beater you carnt beat rust nor prevent it you have to cut it out and weld new piece in sand it back have a look if it isn't that bad eg no holes and can be sanded away just clean and get some deoxidene and brush on then wait 20 then wash off with water if it has holes and is thin cut out and make new piece weld that in and fether out the paint edges and fill with bog rub smooth and flat then spray make shaw you don't touch the steel before you bog as the rust will come strate back
92sierra ht 33s 5in lift 2in zorst gti powered
Post Posted: Mon Feb 06, 2012 9:55 pm
wire wheel/ scraper or screwdriver to scrape it back and get rid of the lumpy bits, soak it in R10, let that do its stuff, when its dry- drown it in penetrol both sides and in any gaps- make sure it gets inside.
after it is dry- give it some more, when its dry- drown in paint.
much the same as the rusty bits you did earlier.
stephen.
Post Posted: Tue Feb 07, 2012 12:04 am
It's been grinded, wire-wheeled and R10-ed for now. Cleaned up and almost ready for paint otherwise -no more engine bay jack mount, indicators are back to the front of the guard and the holes welded and filled, other small dings sorted too.
I think i'm just gonna push sikaflex into every nook and cranny to try seal from any muck buildup.
Post Posted: Tue Feb 07, 2012 1:41 pm
40mm hole saw straight through will remove the rust and make sure it never comes back.
a few spots of weld on what is left of the bracket will hold it in place.
Paint and call it good.
Post Posted: Tue Feb 07, 2012 2:30 pm
yep just make some speed holes and your all good very common place to rust
 Profile YIM
Post Posted: Tue Feb 07, 2012 3:44 pm
As above! The only real way to try and slow it down/stop it.
Speaking of which, What the bloody hell steel are these Suzuki panels made of? They rust like anything! Must be recycled tanker steel or something from the ocean floor!
Lil Foot!
Post Posted: Tue Feb 07, 2012 4:33 pm
recycled fiat body panels springs to my mind
Post Posted: Tue Feb 07, 2012 4:44 pm
its not the steel , but the quality of the paint and sealing process.
that and sierra's are just a dirt trap
Vehicle: Coil Sierra
Post Posted: Tue Feb 07, 2012 9:06 pm
Also painting body panels in flat black can draw moisture in, so does undercoat left unpainted.
Post Posted: Tue Feb 07, 2012 11:28 pm
Moisture isn't a problem in Perth :) It's 35ยบ every day with no humidity, and if it does rain it's generally a 5 minute show.
Post Posted: Tue Feb 07, 2012 11:33 pm
why cant i post replys
Post Posted: Tue Feb 07, 2012 11:35 pm
hmmm, can someone please reply to my tyre pressure thread
says forbidden when i try to reply to it
oh, and sorry to op for hijacking thread :P
never mind, got it working
Users browsing this forum: Google [Bot] and 110 guests
