| Author |
Message |
hobble
Joined: Tue Jul 05, 2011 10:52 pm Posts: 52 Location: brisbane
 Posted: Mon Feb 06, 2012 5:41 pm |
hi guy what fuel tanks have people put in there sierra swb and lwb
Gwagensteve
Joined: Thu Feb 26, 2009 10:30 pm Posts: 13017 Location: Melbourne
 Posted: Mon Feb 06, 2012 5:51 pm |
Is it possible to ask a question in a more vague way?
Do you want a larger tank?
Do you want an EFI tank?
Do you have a SWB or LWB?
Lots of tanks can and have been fitted to sierras over the years.
Christover had a Nissan 280C(?) tank in his LWB I've used all the vitara tanks; 40, 55, 75 Litre
Random long range tanks have been used
Why are you asking?
GRPABT1
Joined: Mon Nov 19, 2007 10:30 pm Posts: 731 Location: Townsville
 Posted: Mon Feb 06, 2012 6:14 pm |
want33s
Joined: Fri Nov 16, 2007 10:30 pm Posts: 8134 Location: Sunshine Coast Qld
 Posted: Mon Feb 06, 2012 7:37 pm |
I'm using one of these in my buggy.
hobble
 Posted: Tue Feb 07, 2012 2:27 pm |
ok i have a lwb ute with ally tray and my tank is no good and i would like a bigger tank 60L 80L 90L just wanted to know what other people have installed in there sierras
thanks
want33s
 Posted: Tue Feb 07, 2012 2:49 pm |
hobble wrote: ok i have a lwb ute with ally tray and my tank is no good and i would like a bigger tank 60L 80L 90L just wanted to know what other people have installed in there sierras
thanks A Baleno tank will fit under a tray. They are ideal when fitting EFI to a trayback, and dirt cheap.
Gwagensteve
 Posted: Tue Feb 07, 2012 3:42 pm |
Ahh - with some more details it's much easier to help. This is a 75 litre GV tank installed behind the cab on a LWB tray back.      You can see it till fits under the stock tray mounts. Steve.
hobble
 Posted: Tue Feb 07, 2012 3:45 pm |
thats great help guys sorry about not putting up all the info nice fit that gv one is
Gwagensteve
 Posted: Tue Feb 07, 2012 4:26 pm |
It's actually a tiny bit too wide - it had to be bashed in a bit on the sides to clear. I have the 55 litre version of the same tank in my car and had the same clearance issues - You can see where the tank sits here:   Mine sits a little higher than the one in the photos above - I had a suspension link I had to clear. These tanks will fit behind the rear axle as well in a tray back .
youda
Joined: Sat Oct 15, 2011 11:44 am Posts: 204 Location: Townsville
 Posted: Tue Feb 07, 2012 5:03 pm |
what about a swb leafy wt zook? or is custom my only option?
_________________ oil lights are like oven alarms, let u know its co
Gwagensteve
 Posted: Tue Feb 07, 2012 5:14 pm |
what's the objective? EFI and/or more capacity?
youda
 Posted: Tue Feb 07, 2012 5:16 pm |
just capacity as much more as i can get
Gwagensteve
 Posted: Tue Feb 07, 2012 5:32 pm |
Custom I reckon.
There were/are up to 80 litre long range tanks for sierras.
Fatzook
 Posted: Tue Feb 07, 2012 6:15 pm |
Only pic I have ATM, but this is an 83L jackaroo EFI tank sitting snuggly between the rails of a LWB 1L trayback.
hobble
 Posted: Tue Feb 07, 2012 8:05 pm |
what year jackaroo is your tank out of its a good fit and good size
Fatzook
 Posted: Tue Feb 07, 2012 8:51 pm |
hobble wrote: what year jackaroo is your tank out of its a good fit and good size Any EFI jackaroo. So thats around 92-02. Mine was from a 98 I believe. They have ample pump size for just about any motor you could fit into a sierra, as the jacko had a 3L V6.
