It is currently Thu Aug 06, 2026 3:03 pm
Post new topic Reply to topic  [ 47 posts ]  Go to page Previous  1, 2
Post Posted: Wed Apr 04, 2012 6:52 am
ok so i need to convince my wife that a sierra will be more comfortable than they are then i need to ether find one someone has already modified to have a bigger motor & auto (really don't want to stuff around with this stuff anymore not enough time) that they want to sell for a descent price.
MAN! i am screwed should have waited to sell the patrol.
is there anything else n the market to compete with a SWB Vitara for size but is better off road that i am not going to need to spend months building?
or am i pretty much screwed till i can find somewhere to store a bigger car then, get another patrol?
company car's make the best 4x4's
Vehicle: SJ50 hardtop!
Post Posted: Wed Apr 04, 2012 7:02 am
Bucket wrote:
No, the Calmini lift kit is NOT worth the money.
:rofl: sure it wasn't the car's problem or the owner.
It was the car. If your here to stir trouble, then fuck off back to your hole.
The kit is crap. It's a lot of coin for a few bits and pieces. The arms are a good piece of work, but do you really wanna pay that much for arms?
You can buy springs and shocks, strut and a-arm spacers for much much less.
NT SJ50
Vehicle: 96 LWB Vit
Post Posted: Wed Apr 04, 2012 7:21 am
You can go with a Vitara and achieve this, but it's going to be a LOT of custom work.
I've done most of what you're talking about with the SE416 vitara - check out my build thread here - viewtopic.php?t=18996
If I had my time over, I would have started with the SV620, it "MAY" mean the Hilux CV conversion would fit without having to widen(it's a possibility but not certain), the V6 allows that little bit more power/torque, and I would definitely have gone for an Auto, which would then mean I may be able to get away with 32's or even 33's. at the moment, it's marginal for drivability on 31's
Hope this helps.
Buddies
I can't leave well enough alone....
Post Posted: Wed Apr 04, 2012 7:56 am
Well the beauty of a well setup sierra is that it should be a more plush ride than factory and hence more comfortable. A LWB will always absorb the bumps better than a SWB though.
Post Posted: Wed Apr 04, 2012 8:48 am
Put some pajero suspension seats in a Sierra
There is ur comfort solved
Post Posted: Wed Apr 04, 2012 5:14 pm
Most sierra's with autos will be full on comp rigs you will find...
Not really.... at least not factory auto... perhaps a Disco or Cherokee? but they are bigger than a Vitara...
If you don't want to build something, you may have to settle for a Vitara, and accept that its not going to go as far as the patrol did.
or buy your wife a buzzbox, and get a manual sierra and park it at a friends house or in a container or something.
or teach your wife to drive a manual...lol
Post Posted: Wed Apr 04, 2012 5:31 pm
i think the issue with your car was not having any extra weight on the car as recommended by calmini + being a soft top & still running standard length struts in the front.
Post Posted: Thu Apr 05, 2012 7:59 am
ok so so far info is
there is no other car on the market in this size that is near as capible or comfortable.
i need to suck it up and accept that unless i spend a fortune and have what is basically a comp car it is not going to compete with the patrol.
so moving on i should get a SV620 / auto
not bother with the Calmini kit but invest in good spring, strut & a-arm spacers, with body lift, ratios & lockers.
by running auto i should be able to run bigger tiers (hoping Simex ET2 or the Silverstone copies)
from looking at the rest of this forum i should be able to make up some sliders, under-body armor, and custom front & rear bars.
what else would you guy's suggest to do to one of these to increase its reliability, power, & all-round performance
Post Posted: Thu Apr 05, 2012 8:32 am
5.12:1 diff ratio's from a 1.6l manual vit & a GV steel front diff
Vehicle: 2001 XL7
Post Posted: Thu Apr 05, 2012 10:09 am
just fly to queensland and drive this home http://www.boostclassifieds.com.au/adve ... -Sale.html
put some mags on it and presto - good looking 4b that has the mods done.....
Post Posted: Thu Apr 05, 2012 11:33 am
was hoping to get a SWB as i have extremely limited space.
but other than that just what i am looking for.
Post Posted: Thu Apr 05, 2012 11:51 am
X2 on flying to QLD and buying that ^^
it's all done, whats an extra foot of wheelbase between friends? lol
Post Posted: Thu Apr 05, 2012 11:57 am
how much longer are the LWB than the SWB?
Post Posted: Thu Apr 05, 2012 12:04 pm
i would think about 2 feet longer. basically the length between the back edge of the front door and the back of the back door at the sill.
Post Posted: Thu Apr 05, 2012 12:06 pm
its tombutts car from on here so you could always pm HIM.
Post Posted: Fri Apr 06, 2012 9:30 pm
4.2 transfer gears are an excellent choice, but there are no replacement diff ratios, so road driving with 31" tyres is marginal.
this isnt true of all vitaras, wide track ones have 4.6 diff ratios stok so you can swap them with 5.12s from other vitaras to achieve spot on gearing for 31" tyres.
on a side note, slow check this out sorry for blatant plug it might suit you though
vitara
i changed it back to standard for the sale, but ive also got 5.12 diffs for it (front one in steel) 40 mm dobinsons suspension lift (prob like 3000 ks on it) and five 31X10.5" a/ts (prob less than 1000 ks on them) on black sunnies.
lwb vitaras are still half the size of a patrol
Post Posted: Fri Apr 06, 2012 10:26 pm
LWB Vit with 2" suspension, 2" body lift and 31s, LC80 with 2" suspension and 31s.
Height about the same, but length and width VERY different!
Users browsing this forum: No registered users and 933 guests
