It is currently Thu Jun 25, 2026 11:57 am
Vehicle: 1.3 Tin Top
Post Posted: Sun May 20, 2012 1:05 pm
I have a coolant leak on the back of the head as far as i can see, on the exhaust side. its been there since i bought it but has recently got a little worse.
Coolant is dripping down the block and onto the bell housing.
Does this mean new engine or head gasket maybe? should i try some chemiweld or similar
Post Posted: Sun May 20, 2012 1:09 pm
Make and model? Which engine?
Post Posted: Sun May 20, 2012 1:57 pm
sierra 96 hard top 1.3 carb
Post Posted: Sun May 20, 2012 3:29 pm
Check the chock coolant hoses going into the back of the carby For leaks.
Post Posted: Sun May 20, 2012 3:49 pm
I would check that it isnt a heater hose squirting it over there
Give it a clean and let it run up to temp to build some pressure and have a good look around with a mirror
Post Posted: Sun May 20, 2012 6:05 pm
It is definately dripping from the head behind the exhaust manifold flange.
i will have a good look tomoro afternoon.
Post Posted: Sun May 20, 2012 6:09 pm
when you say behind, behind as in between manifold and firewall or between manifold and block?
Post Posted: Sun May 20, 2012 6:21 pm
between block and manifold. im guessing but looks like from between head and block
Post Posted: Tue May 22, 2012 4:55 pm
really odd but it seems to have stopped
Post Posted: Tue May 22, 2012 6:31 pm
maybe all the coolant has gone? if its still got coolant then there is no pressure to push it out. when its warm it will push it out again.
Post Posted: Tue May 22, 2012 8:26 pm
it used a small amount of water this morning then i topped it up before i came home. checked when i got home, i cant see any more coolant on the bell housing, the rad hoses definately had pressure in them and after letting it cool the water level has not dropped
Users browsing this forum: No registered users and 149 guests
