It is currently Thu Aug 06, 2026 1:46 am
Post Posted: Sat May 26, 2012 6:35 pm
I'm thinking if i get the JimnyBits 24% recuction gears coupled with 31's or 30's and a guard chop how would the stock 1.3 go? Has anybody done this? if so help appreciated
2004 Jimny
2" ome lift
15mm spacers
235 75's
Post Posted: Sat May 26, 2012 6:41 pm
Speak to mubby
Post Posted: Sat May 26, 2012 9:36 pm
I had the 20% TJ gears...went well... BTW be prepared for drive line breakages once you got to 31s and a locker or 2...
Post Posted: Sun May 27, 2012 12:55 pm
I have pushd the firewall quaters back on both sides, and cut into the sills. Is being welded up now and shouldbe finished today. Still searching for a nice set of flares to suit, then will cut the guards as necessary.
Post Posted: Sun May 27, 2012 12:56 pm
think 24% would be too much IMO
vvts got 20% and if Im not wrong they still end up doing 4000rpms at 100Km/h (from the 3000-3200 factory)
non-vvts already do 4000rpms from factory... so adding even more reduction would be crazy for highway driving.... go for the sierra transfer case
Post Posted: Sun May 27, 2012 1:04 pm
BertZook, when you say VVT's got 20%, I assume you are referring to the Transfer Case High range. This is true but the gear box is also different, which compensates somewhat. I have done very similar... 32" tyres with an Auto VVT case in my manual Jim. It does just over 4,000 at 100k's so yes it is a bit high but bearable and is a reasonable tradeoff for the offroad benefit.
On Sierra cases, I can see no benefit in that because all Sierra cases are lower ratio in high... 1.409 and 1.580, so its actually worse. Add a gear set and it doesn't get any better.
Post Posted: Sun May 27, 2012 7:25 pm
Hey bert. are you running the original m13a? what i want to find out is jow it goes with the 31s but geared
2004 Jimny
2" ome lift
15mm spacers
235 75's
Post Posted: Sun May 27, 2012 7:36 pm
I should think it would go ok. The gearing would still be better than stock. No powerhouse but able to crawl through a lot easier.
Post Posted: Sun May 27, 2012 7:59 pm
My last Jimny was an M13A, it had 24% reduction gears and 235/75R15s.
It ran really well in the bush and around town but highway driving was tedious.
Running 31s with 24% gears would be great all-round in my opinion.
Post Posted: Sun May 27, 2012 9:21 pm
Thanks for the tips guys :) might be seeing a jimny on 31's soon :)
2004 Jimny
2" ome lift
15mm spacers
235 75's
Post Posted: Sun May 27, 2012 9:24 pm
I'd imagine a M13 would be better than a G13BA, and it's just fine with the carby ;)
Vehicle: 2000 JX Jimny
Post Posted: Sun May 27, 2012 10:04 pm
I see your running 235s with 2" lift and 15mm spacers. Much scrubbing?
Just turning em!
Post Posted: Mon May 28, 2012 12:50 am
yeah.. sorry bout my english skills :lol:
Im just saying that in order to do 100km/h:
VVT's do 3200rpms factory.... the only option its 20% reduction witch if I remember right from some builds with 31's they end up doing 4000rpms to get to 100km/h witch u can still do it
NON-VVTs do 4000rpms factory..... the only option is 24% reduction (so even lower).... so wht would be the end result?..5200rpms t do 100km/h???? I get annoyed when I do more than 4200rpms... I would go crazy with 5000.... plus bye bye fuel economy
and yes Im talking about Hi range... either way this trialjimnys kits affect hi and low at same %
Vehicle: Suzuki Jimny 2010
Post Posted: Mon May 28, 2012 6:46 am
My VVT does 3800 stock?
Post Posted: Mon May 28, 2012 8:30 am
Yep, my Jimny does the same at 100.
Bert, 3200 was my VVT Jimny with stock gears and 235s.
Post Posted: Mon May 28, 2012 8:32 am
Also if you're wanting 31's and reduction gears on a Jimny.. Maybe it's less of a road car than you want it to be and you could maybe sit on 80-90 on the freeway?
Post Posted: Mon May 28, 2012 7:56 pm
I got 31's with a g13bb motor, at 100kph I sit on 4150rpm. i have the 24% reduction gears. I use mine as a daily and I like the setup. Whenever I go on the highway I only sit at 100kph it feels comfortable at that.
Post Posted: Mon May 28, 2012 8:33 pm
:hey: Hi Andrew, thought you'd sold the Jim?
Post Posted: Tue May 29, 2012 2:22 pm
Bert, 3200 was my VVT Jimny with stock gears and 235s.[/quote]
my bad :oops:
Users browsing this forum: No registered users and 772 guests
