It is currently Fri Nov 06, 2026 2:34 pm
Post Posted: Fri May 25, 2012 1:31 pm
Need to sort out my brake lines and get them extended but need/want to know by how much?!
I've got a 2" body lift and 2" shock/spring on a Maruti with 31's
Id rather do it once properly instead of going back so was wondering how much would you add to the original (stock) length
Post Posted: Fri May 25, 2012 4:17 pm
100mm longer. Plenty long enough for a flexxy spua sierra.
Post Posted: Fri May 25, 2012 5:30 pm
I have to do this, im at work, will not be home till the 6th, so to order them so they there, what is stock or what lenght total ?
Post Posted: Fri May 25, 2012 5:52 pm
Thanks BlueSuzy.....getting them done tomorrow :)
Vehicle: Sierra 1.6
Post Posted: Tue May 29, 2012 2:21 pm
Hey mate where dud u get them done (I'm in Perth too) n how much?? Did u use braded lines or rubber
Vehicle: multiple R32's, wtd sierra
Post Posted: Tue May 29, 2012 4:08 pm
as above ^^ would be good to know where you got them done and how much?
Post Posted: Tue May 29, 2012 4:31 pm
Hyundai Excel front hoses are same fittings as Sierra fronts but 100mm longer.
Not sure about the length of the rear. I spose I should walk outside and have a look.
Post Posted: Wed May 30, 2012 4:58 am
Any year or all years ?
Just what i need.
Post Posted: Wed May 30, 2012 6:30 pm
94-2000 I think.
Post Posted: Wed May 30, 2012 7:31 pm
Try Pre 95 excel the ones after 95 have a bracket on it I'd upload a pic but no camara
Post Posted: Wed Jun 06, 2012 2:09 pm
Got them done through Enzed....guys name is Peter Collins and he's mobile so he can come to you (Mob: 0419 043 102)
Fully braided, 110mm longer with protective outer plastic hose....tested to full ADR regulations/pressure....just under $150 for front two (usually around $180)
The reason it's so expensive is fittings and the testing as it needs to be done inhouse
If you don't want braided and are happy with normal rubber they're around $120 but he'll do you a deal if you mention i got mine done with him
I had to bring mine in to make sure he got the correct fittings but he knows what to use now so all he needs is length and if its braided/rubber
I know it may sound abit much but brakes are one thing i didn't want to skimp on
Vehicle: Sierra 1.6
Post Posted: Fri Jun 08, 2012 3:21 pm
I totally agree masterA I'll give him a call thanks.
Vehicle: Sierra 1.6
Post Posted: Fri Jun 08, 2012 3:23 pm
Ps what name should I be givin him haha
Users browsing this forum: Google [Bot] and 128 guests
