It is currently Thu Aug 06, 2026 8:15 am
Vehicle: SJ51T
Post Posted: Tue May 29, 2012 8:34 pm
I moved my front axle in the Sierra forward 30mm by redrilling the ubolt plate and spring perches.
now the pitman arm/tie rod end is impacting on the drag link.
my question is.. if i unbolt the tierod end from underneath the pitman arm and rebolt it on top of the pitman arm which would raise the tie rod about 1.5 - 2 inches.
would this improve the impacting situation when I hit bumps ?
-Jon
Humble beginnings
Post Posted: Tue May 29, 2012 8:36 pm
You can't. The hole in the pitman arm is tappered to suit the tappered shank of the TRE.
Move your diff back, or steering box forward.
Post Posted: Tue May 29, 2012 8:38 pm
Bumpstop spacers.
Vehicle: SJ51T
Post Posted: Tue May 29, 2012 8:39 pm
I don't like those answers so I am going to put my hands over my ears and go "LALALALALALALALALLA not listening!"
re-drill tapered hole perhaps :|
Humble beginnings
Vehicle: SJ51T
Post Posted: Tue May 29, 2012 8:40 pm
what about get a new flat pittman arm so at least it is raised 20mm or so
Humble beginnings
Post Posted: Tue May 29, 2012 8:41 pm
It will be too deep of a taper if you re-drill from the other side. TRE will flog about in the hole.
Post Posted: Tue May 29, 2012 8:42 pm
That will cost you a bit, won't be legal ( not that anyone would notice) , but more importantly, lifting the drag link up at the pitman arm end will increase bump steer.
Vehicle: SJ51T
I don't like the tone of your answer Fatzook but I do like (out of context) the term "flog about in the hole"
Humble beginnings
Post Posted: Tue May 29, 2012 8:44 pm
No way!
Tight hole is the best 8)
Vehicle: SJ51T
Post Posted: Tue May 29, 2012 8:45 pm
re-drill
Humble beginnings
There's no flatter pitman arms that I'm aware of that bolt to a Sierra steering box. Vitara boxes have a very flat pitman arm, but it's not a solution for you before Saturday. :D . Bumpstop spacing is in your near future.
Vehicle: SJ51T
Post Posted: Tue May 29, 2012 8:48 pm
Thanks OB1
There will be grinding and banging in Toolangi come Saturday, and it will be the call of the mighty Sierra.
Humble beginnings
Post Posted: Tue May 29, 2012 9:11 pm
Time for power steering then Armsup
I have the BenT kit with vitara power steer and it mounts the PS box approx 20mm further forward to help with rub/redrilled perches.
Post Posted: Tue May 29, 2012 9:24 pm
or you could fit a pitman arm out of a jimny, about 7mm shorter than sierra.
Vehicle: SWB Sierra
Post Posted: Tue May 29, 2012 10:34 pm
Jon, you are going to have to space it 50mm, steering is going to be a nightmare on loose rough tracks if you don't.
Only problem with this is that you currently only have ~50mm bump clearance.
Post Posted: Wed May 30, 2012 1:32 pm
Interesting.
So how do you get around the Jimny pitman arm having a different tapered spline to the sierra box?
Post Posted: Wed May 30, 2012 3:19 pm
Fit the whole jimny box
Post Posted: Wed May 30, 2012 6:07 pm
22mm is the magic number, to avoid these issues.
Too late now,
but gives you an excuse to look at power steer options :)
Post Posted: Wed May 30, 2012 6:19 pm
Could this be more cryptic? I assume you mean 22mm of axle relocation, but you could as easily mean 22mm of bumpstop spacing.
In any case, Jon is running new 33's so needs all the help he can get to clear the firewall, and will likely need bumpstop spacing to keep the tyres out of the inner guards, so with bumpstop spacing he avoids steering issues and gains clearance.
22mm of axle relocation may well allow stock bumpstops and no steering contact, but piggles ran 30mm relocation, 50mm bumsptop spacing and I had no steering contact even with a sleeve on the drag link.
Vehicle: SJ51T
Post Posted: Wed May 30, 2012 8:22 pm
I have just drawn up the plans for the bump stop spacing, 25mm block at the front to bring it to 18mm of "daylight" as Steve puts it.
and 30mm block at the back (which has to be welded on) to leave 20mm of daylight.
The firewall is fine atm but I do have a power steering set up on it's way next week thanks to pay-day today.
But as far as what parts of the BenT kit I will need... that's another story.
-Jon
Humble beginnings
Post Posted: Wed May 30, 2012 8:27 pm
Drovin mentioned only the fitting of the pitman arm. Just curious how this is to be done.
Post Posted: Wed May 30, 2012 8:36 pm
BenT kit is pretty straight forward you will need the whole kit, as its really just a bracket for the pump, spacer for the rad and a wedge for the PS box (exxy bit). If you need a hand let me know I can send pics of line routing etc.
Users browsing this forum: No registered users and 395 guests
