| Author |
Message |
SierraDan
Joined: Fri Feb 04, 2011 10:55 pm Posts: 9348 Location: Newcastle
 Posted: Wed May 30, 2012 5:47 pm |
Stupider? I think idiot is a more general term..
_________________ mlm
Fatzook
 Posted: Wed May 30, 2012 5:48 pm |
SierraDan wrote: nowhere productive. Same place most other Tech threads end up...... Why fight it?
31zook
Joined: Tue Mar 24, 2009 10:30 pm Posts: 9242 Location: maito
Gwagensteve wrote:  And if they are both diff centres, isn't that confusing? As far as i know thats a carrier
SierraDan
 Posted: Wed May 30, 2012 5:49 pm |
Like a basket?
want33s
Joined: Fri Nov 16, 2007 10:30 pm Posts: 8134 Location: Sunshine Coast Qld
 Posted: Wed May 30, 2012 5:57 pm |
Gwagensteve wrote: That's why I use the term spider gear or "pin" rather than pinion when referring to diff centres.
I agree with the use of "hemisphere" but I think that's in even less common use than third member, and as you pointed out, it doesn't differentiate between dropout style diffs and dana/sailsbury. Steve. Steve isn't your use of "spider gear or 'pin' " adding to the multiple name confusion? Why does the term "hemisphere" need to differentiate(no pun int..) between Salisbury and Banjo. A hemisphere is almost identical between them anyway. Let's face it... The car wasn't invented and each part named by one guy. The car has been designed and built and modified and changed and improved by thousands of engineers over the years and being from different times and different countries they came up with different names for the same parts, so now there are several possible terms for the same part which leads to confusion... EG: The computer in your car might be an ECM or EMS or ECU.
Gwagensteve
Joined: Thu Feb 26, 2009 10:30 pm Posts: 13008 Location: Melbourne
 Posted: Wed May 30, 2012 6:14 pm |
Not really, want33's, spider gears and pins are different parts, but they do relate to each other, so I don't think it's really confusing - more pins = more spider gears.
I don't consider Dana/sailsbury type diffs to have any sort of name for the middle bit of the housing another than carrier, as it's basically integral to the axlehousing. The yanks use "centre section" IIRC ( which is different to "centre") I'm just not really fond of "hemisphere" because it's a catch all term.
Take an MQ/ MK patrol. The front end is dana style and the rear is dropout third member style- they both have a hemisphere, but the approach and assembly of each end is totally different
want33s
 Posted: Wed May 30, 2012 6:21 pm |
Gwagensteve wrote: Take an MQ/ MK patrol. The front end is dana style and the rear is dropout third member style- they both have a hemisphere, but the approach and assembly of each end is totally different But that's my point. The parts (hemispheres) are basically identical so should be named accordingly, why should the assembly or dissassembly procedure dictate the name of the part?
Gwagensteve
 Posted: Wed May 30, 2012 6:30 pm |
That happens all the time though. We have unit bearings, for example, Which have all the same parts as a normal wheel bearing assembly, but are pressed together, so they are called something different to differentiate themselves from a regular, user-serviceable wheel bearing. It's still a wheel bearing and still has a hub, bearings, etc etc. IMHO hemisphere implies an "area" of the axlehousing, Not necessarily anything that's in it. Anyways, it's all semantics now. The alternative might be technical German, where every word is a precise description of its function or assembly. Much less confusion....... Much longer words.  Steve.
want33s
 Posted: Wed May 30, 2012 6:59 pm |
Sort of reminds me of the poor under recognised hub. The wheel was and is a fantastic invention recognised internationally since the dawn of time but without a hub a wheel cannot be put to work ?
Shansh
Joined: Sun May 23, 2010 9:35 am Posts: 1816 Location: Goulburn NSW
Vehicle: Ducati Monster
 Posted: Wed May 30, 2012 7:10 pm |
atari4x4
 Posted: Wed May 30, 2012 7:11 pm |
diff centre
Shansh
 Posted: Wed May 30, 2012 7:13 pm |
hey stop confusing people, im trying to help with repetition!!! third member
want33s
 Posted: Wed May 30, 2012 7:18 pm |
Zuccinni
Joined: Fri Aug 20, 2010 9:36 pm Posts: 168 Location: Bridgeman Downs
Vehicle: 94 Sierra
 Posted: Wed May 30, 2012 7:31 pm |
Will this help?
_________________ Serious
Unbiased
Zook
Users
Know
It
atari4x4
 Posted: Wed May 30, 2012 7:41 pm |
nope
diff centre
Shansh
 Posted: Wed May 30, 2012 7:42 pm |
mrw82
Joined: Tue Jul 03, 2007 11:30 pm Posts: 1350 Location: stuck in a hole. not off road, just deception bay.
 Posted: Wed May 30, 2012 8:03 pm |
Taken from the FSM. Should settle all arguments, you can't argue with what Suzuki call their parts. Although I'm sure someone will try...
SierraDan
 Posted: Wed May 30, 2012 8:07 pm |
No. I call that the workshop manual..
mrw82
 Posted: Wed May 30, 2012 8:10 pm |
Whatever, its a genuine Suzuki manual for the Sierra.
SierraDan
 Posted: Wed May 30, 2012 8:18 pm |
Haha, I'm just joking..
303zuke
 Posted: Wed May 30, 2012 8:49 pm |
The particular name of an item is not really that important, because each of these have a different term in different parts of the world. If you have got most of your Tech from US websites or magazines, then you will tend to use US terms. Likewise with British or Aus stuff. For example Ring and Pinion is a fairly well recognised US term, but the British call them a Crown Wheel and Bevel Gear! The important part is to know what it is and what it does. The point of this thread wasn't to argue about the names of bits, but to have clarity in what everyone is talking about.
It's like buying a Beer in a pub in Aust. Depending where you are in the country, you might ask for a Pint, Pot, Schooner or Jar. Get it wrong and you'll get either a blank stare or a torrent of abuse (especially on State of Origin night!). But the important thing is to make sure it's Big and Cold and paid for by a mate!
Shansh
 Posted: Wed May 30, 2012 8:54 pm |
schooner....................................third member!!!!!!
Fatzook
 Posted: Wed May 30, 2012 8:55 pm |
Shansh wrote: schooner....................................soft member!!!!!!  Jug...............................third member
303zuke
 Posted: Wed May 30, 2012 8:56 pm |
Fatzook wrote: Shansh wrote: schooner....................................soft member!!!!!!  Jug...............................third member  Jugs.......................Boobies!
Shansh
 Posted: Wed May 30, 2012 8:57 pm |
Fatzook wrote: Shansh wrote: schooner....................................third member!!!!!!  Jug...............................no member
Fatzook
303zuke wrote: Fatzook wrote: Shansh wrote: schooner....................................soft member!!!!!!  Jug...............................third member  Jugs.......................Boobies!  And there we have it! Destination reached!!
Shansh
 Posted: Wed May 30, 2012 8:58 pm |
all roads lead to the boobies!!!
KEENSY85
Joined: Wed May 09, 2012 12:46 am Posts: 1742 Location: north brisbane
Vehicle: 1985 lwb sierra UTE
 Posted: Thu May 31, 2012 7:29 pm |
I rather like learning the proper parts names it is very important to especially when u need to buy replacement parts from a suplier
_________________ Green? greeeen is nice !
KEENSY85
 Posted: Thu May 31, 2012 7:30 pm |
All agreed BOOBIES
rufftruck
Joined: Tue Jan 25, 2011 8:43 am Posts: 40 Location: newcastle
 Posted: Thu May 31, 2012 7:35 pm |
I think next time i ask a question ill have to be more precise in what i ask ?
