[ 6 posts ] |
Print view
Previous topic | Next topic
| Author |
Message |
buzbox
Joined: Thu Jul 16, 2009 11:30 pm Posts: 3600 Location: Wollongong NSW
Vehicle: LWB Sierra & XL7
 Posted: Sun Jun 03, 2012 2:38 pm |
I'm probably worrying about nothing but thought I'd just double check.
I have an engine here suitable for rebuild, I've pulled the head off to get it reco'd, I got the intake manifold from out of the shed to give it a clean and it seems that it's from a Baleno. It appears to be almost identical to my vit's manifold except for some very minor differences.
Would this cause any unexpected issues when I swap it into the Vitara, eg with the gearbox, engine mounts wiring or any other plumbing?
And I've just noticed that the ditributor cap and rotor button are different, It wouldn't cause any problems if I just swap them over with my original dizzy?
Thanks,
xedent
Joined: Mon Jun 15, 2009 11:30 pm Posts: 895 Location: Sunshine Coast, QLD
 Posted: Sun Jun 03, 2012 3:43 pm |
I think you will find the wiring and ecu will be different, better to use your vit head if you can.
_________________ My Maruti build, Click WWW
want33s
Joined: Fri Nov 16, 2007 10:30 pm Posts: 8134 Location: Sunshine Coast Qld
 Posted: Sun Jun 03, 2012 3:51 pm |
Use everything from your Vit head on the Baleno including the cam.
buzbox
 Posted: Sun Jun 03, 2012 3:56 pm |
I did a bit more digging around and I actually think it's a '96-98 Vit engine which I presume is exactly the same as Baleno. I could be wrong but didn't they use a Coil Over Plug arrangement?
The only difference in wiring that I can think of would be for the Dizzy, All the sensors on the block are the same and on the head there are very minor differences like breather hoses.
royce
 Posted: Sun Jun 03, 2012 4:48 pm |
I dont believe any Baleno ran the throttle body over the rocker, which all Vitaras did
remember there are 3 different types of Vitara G16B
BlueSuzy
 Posted: Sun Jun 03, 2012 4:53 pm |
All baleno's intake comes out next to cam cover, like jimny
Only later GV's? 2 doors got coilpacks, With intake like baleno's
98'on balenos ran twin coil packs. with a crank sensor. No dizzy after then, i think in anything G16b Even the later GV's had cranksensors,
[ 6 posts ] |
Users browsing this forum: No registered users and 134 guests
