It is currently Wed Aug 05, 2026 12:54 pm
Post new topic Reply to topic  [ 76 posts ]  Go to page 1, 2, 3  Next
Post Posted: Thu Jun 28, 2012 6:11 pm
i have access to reasonably priced gas and reckon it could be fun to have a 35 or 50hp shot on my sierra.
has anyone tried gas? how did it go? should i use a wet or dry system?
Post Posted: Thu Jun 28, 2012 6:21 pm
you're going to need 2 of the big bottles.
Post Posted: Thu Jun 28, 2012 6:27 pm
I've looked into this- I was concerned that with 35's I wouldn't have enough punch for long climbs. This hasn't proved to be the case for me.
I looked at a 50hp shot more than that and you'd want engine work in the opinion of NOS. You need a wet setup or the car will lean out. I was looking at using a 3000rpm rpm switch to arm it and a wot switch to engage the spray. You don't want to hose an engine under 3k- the loading at tdc is too much.
Bear in mind that with 60% more power an an equal increase in torque, optimal gearing is very different when on spray. I haven't looked at it since I've gone G16 because low range would be too low to use it- I'd be all over the limiter in low range 4th, but I couldn't pull high range until I was on spray.
Something to bear in mind.
It's a much better idea than a turbo conversion IMHO, because the engine isn't under increased load all the time, only for very short periods where needed.
Post Posted: Thu Jun 28, 2012 6:54 pm
that can be arranged :wink:
Post Posted: Thu Jun 28, 2012 6:56 pm
i think we need to see how much gas the 1.3 can take before we get engine parts screaming their way out through the sump or block. :D
Post Posted: Thu Jun 28, 2012 6:58 pm
I don't have a running 1.3 anymore. If the 1.6 stops I will just get anouther one
Post Posted: Thu Jun 28, 2012 6:59 pm
how much nitrous is it going to take to get the 1.3 going again.
Post Posted: Thu Jun 28, 2012 7:03 pm
Don't no if it's relevant but rett runs nos on his 1.3 in his comp truck
Post Posted: Thu Jun 28, 2012 7:53 pm
Can I have one? :P Wonder how long it would last on my 285cc bike Armsup
Lil Foot!
Vehicle: 1999 Jimny
Post Posted: Thu Jun 28, 2012 8:06 pm
I wouldn't mind 50hp shot on my TL1000s......... would be fun at about 180 :twisted:
Vehicle: Ducati Monster
Post Posted: Thu Jun 28, 2012 8:30 pm
hope you have a decent steering damper :roll:
Post Posted: Fri Jun 29, 2012 12:30 am
It was nos and turboed i think 8O 8)
Sounds like an awesome project guys :)
Post Posted: Fri Jun 29, 2012 4:14 am
i have a g16 block under the house that has had nos run through it the head got ripped off cracked chunks out of the block where the head bolts go not sure how much spray they used cause i got it off a guy who got it off a guy ill get pics if i get time this weekend.
Post Posted: Fri Jun 29, 2012 7:10 am
Yep Sierra motor with a turbo and a bottle of happy gas behind the seats :lol:
How would nitrous go on g13ba/g16a on LPG/propane?
Post Posted: Fri Jun 29, 2012 8:01 am
Just breathe it all in and pretend.
Post Posted: Fri Jun 29, 2012 8:17 am
:lol:
Wouldn't need to leave the house!
Post Posted: Fri Jun 29, 2012 10:13 am
I have a 35 to 75hp tune able kit on the way. Should be fun with the auto. Might have to run it down the 1/4 mile and see how it goes. Under 20sec would be cool
Post Posted: Fri Jun 29, 2012 10:32 am
A turbo mighty boy does 18's.
You should be safe
Post Posted: Fri Jun 29, 2012 10:47 am
You should be safe
Shep? Safe!? :rofl: :rofl: :rofl:
Post Posted: Fri Jun 29, 2012 10:57 am
Awesome*
Vehicle: LJ80
Post Posted: Fri Jun 29, 2012 12:11 pm
that would be pretty funny
Post Posted: Fri Jun 29, 2012 12:18 pm
You should be safe
That is as likely as you knowing something about anything. :wink:
Post Posted: Fri Jun 29, 2012 12:21 pm
are you going to try & do a bit of a stealth install or you're not that fussed? would be cool to have it all hidden out of sight. 8)
Post Posted: Fri Jun 29, 2012 12:45 pm
Don't care where it goes. According to the police it is road legal as long as it is fitted corectly. Is nos rice?
Vehicle: A shed full of pieces so far
Post Posted: Fri Jun 29, 2012 12:48 pm
Pretty sure qld you can have the system fitted but you can't have the bottle connected.
Post Posted: Fri Jun 29, 2012 12:51 pm
yes, nos is rice. being an old prick you might haven not seen Fast and the Furious... i really think you need to see it. :rofl:
hence my comment about needing 2 of the big bottles earlier.
Post Posted: Fri Jun 29, 2012 12:53 pm
same as SA
Post Posted: Fri Jun 29, 2012 1:16 pm
Whats a system cost
How long would a bottel last
Would be nice for hills and overtaking
Post Posted: Fri Jun 29, 2012 1:17 pm
same as SA
Sucks to live there then
Post Posted: Fri Jun 29, 2012 1:37 pm
You should be safe
I know not to set my car on fire :thefinger:
Users browsing this forum: No registered users and 210 guests
