It is currently Sat Nov 07, 2026 4:22 pm
Vehicle: 91 WT 1.6EFI
Post Posted: Sat Jun 30, 2012 5:05 pm
hooked everything up today when the ignition was on "on" all the dash lights lit up, the check engine light did not. tried to start it and the starter motor made a noise like it was going to crank but it didn't. it sounded like the battery was dead but I checked it with a multimeter and its fine. tried to start it twice more, same noise. the fourth time nothing happened no dash lights at all. currently all the fuses are fine and the clock works when the ignition is off however when I turn it on the clock turns off. are these hopefully the symptoms of a easy fix?
Post Posted: Sat Jun 30, 2012 5:14 pm
Sorry mate we really need a bit more info, is this a conversion that you have just done, is it an engine you have just worked on or did you just go to get in it one day and this happened ???
Post Posted: Sat Jun 30, 2012 5:17 pm
Is this a G16 transplant into a Sierra? Have you checked all your earths? Start with the main ones first
Post Posted: Sat Jun 30, 2012 5:21 pm
yup sorry it is a vit g16b conversion into a sierra, and this is turning the key for the first time. ok I'll go have a look at the earths and I put the battery on charge just in case. it hasn't been used for a week.
Post Posted: Sat Jun 30, 2012 5:35 pm
ok I double checked everything and it was fine. tried it again and all the lights came back on and it cranked. its getting a bit late and I only have a manifold on the engine so I'll pick it up again tomorrow. cheers guys.
Post Posted: Sat Jun 30, 2012 5:38 pm
I assume it's an EFi? Who did the wiring? If it doesn't fire you might just have to start from the beginning and check everything
Post Posted: Sat Jun 30, 2012 5:47 pm
yes it is an efi. I did the wiring myself. ha probably a recipe for disaster but I triple checked everything as I went through. but ya if it doesn't fire there were a few areas around the dizzy where the wiring was a bit confusing that I'll go back through.
Post Posted: Sat Jun 30, 2012 8:02 pm
This sounds promising - did you meter the battery while it was cranking or just sitting? You need to know the battery holds voltage while under load, or it could be farked.
Hopefully it's that simple!
Post Posted: Sat Jun 30, 2012 8:19 pm
Voltage is no real indication of a battery's state of charge.
Users browsing this forum: Google [Bot] and 112 guests
