It is currently Sat Nov 07, 2026 1:53 am
Post Posted: Thu Jul 05, 2012 8:02 pm
I did a search but couldn't find anything helpful. Just after some information about what's involved in doing a spoa on my 95 Sierra with standard suspension. Is there anything I need to change? What are the pros and cons?. Sorry if this has been asked before or if it seems really obvious
Post Posted: Thu Jul 05, 2012 8:04 pm
CONS:
You are in QLD, so forget it.
What are you trying to achieve? Are you trying to fit a particular size tyre? Or do you just want poser lift?
What sort of terrain do you drive?
Post Posted: Thu Jul 05, 2012 8:09 pm
Was mainly trying to achieve cheap lift. Usually just drive muddy forest tracks
Vehicle: SJ50 hardtop!
Post Posted: Thu Jul 05, 2012 8:15 pm
Spring over isn't a cheap lift option...ever
NT SJ50
Post Posted: Thu Jul 05, 2012 8:16 pm
Ok was t sure what was involved
Post Posted: Thu Jul 05, 2012 8:17 pm
cheapest lift option is 2in body lift blocks from just_cruisin
Vehicle: sierra
cheap lift
OME 40mm comfort, 2"BL nice simple alot less assfucking and a better result imo
Post Posted: Thu Jul 05, 2012 8:18 pm
You did a search on SOA and didn't find anything useful????
SOA is illegal in QLD so unless you ONLY drive private property forget it.
Vehicle: 4wd
Post Posted: Thu Jul 05, 2012 8:19 pm
What size tyres do you want to run?
Watch out or you'll get sued.
Post Posted: Thu Jul 05, 2012 8:32 pm
31's for now
Post Posted: Thu Jul 05, 2012 8:39 pm
pretty sure just from being on here for like 6months, that its been covered a million times. so im not sure about the whole search thing but anyways...
to run 31's on a sierra you can run 2" body lift and a little chopping with some bumpstop extensions and that will get you 31's under it... (i own a much more comfortable vitara so don't take it the be all and end all on what i say)
spring lift in no Vehicle will allow you to run bigger tyres...
mainly because the idea is the vehicle articulates more than the stock standard. therefore a body lift is the way to go :)
Edit : (body lift will be the cheap lift to attaining bigger tyres)
Stocker
Vehicle: sierra
Post Posted: Thu Jul 05, 2012 8:43 pm
spring over involves alot of work, if you have a nt i wouldent evin try, but to do it u need high steer, plus a lot of other stuff and an engineers cert, as far as i know in qld they wont allow it
Post Posted: Thu Jul 05, 2012 9:37 pm
Some hammering should be all that's needed with a body lift.
Only need bump stops with just a spring lift. I had 31's with 2" spring and extended bumpstops. Wouldn't do it any other way.
Users browsing this forum: No registered users and 128 guests
