| Author |
Message |
juzzys
Joined: Thu Aug 18, 2011 12:09 am Posts: 142 Location: burp's on the north side
Vehicle: 88 1ltr zook
 Posted: Sat Jul 07, 2012 3:42 am |
Does nt 1.3 have a higher ratio diff centre then nt 1 ltr?
_________________ when boredom sets in ....
303zuke
 Posted: Sat Jul 07, 2012 4:21 am |
Yes.
NT 1.3 is 3.909 1.0lt is 4.11
But they're not interchangable as both the ring and pinion set and also the whole housing are different sizes (1.0lt is smaller), but you can swap the complete axles (Drum to drum, or disc to disc).
juzzys
 Posted: Sat Jul 07, 2012 7:12 am |
Thanks mate! So if my 1 ltr is an 88 model and it has the wider tunnel etc, would It still be running the 1ltr axles? It's a late 88
Gwagensteve
Joined: Thu Feb 26, 2009 10:30 pm Posts: 13007 Location: Melbourne
 Posted: Sat Jul 07, 2012 7:36 am |
zooky08
Joined: Fri Nov 27, 2009 10:30 pm Posts: 3426 Location: imbil/gympie. qld
 Posted: Sat Jul 07, 2012 7:44 am |
bit of confusion going on here. 88 is a nt 1.3 not a 1lt. it has a 1.3l engine. it willl have nt diffs with 3.9 1.3l size centers. nt 1l has a higher ratio and are smaller but not interchangable with nt 1.3 or wt 1.3
_________________ 03 Jimny 30 km2s 75mm lift f&r locked winch
juzzys
 Posted: Sat Jul 07, 2012 7:50 am |
Nar it's an 88 sj410 1ltr.. I think it's the very last of the 1ltr
shep
Joined: Thu Mar 29, 2007 11:30 pm Posts: 14498 Location: Here there everywhere
 Posted: Sat Jul 07, 2012 7:51 am |
zooky08 wrote: bit of confusion going on here. 88 is a nt 1.3 not a 1lt. it has a 1.3l engine. it willl have nt diffs with 3.9 1.3l size centers. nt 1l has a higher ratio and are smaller but not interchangable with nt 1.3 or wt 1.3 I know a fella that has a 1998 1.0 so a 88 is very possable
_________________ JEEPJEEPJEEPJEEPJEEPJEEPJEEPJEEPJEEP
zooky08
 Posted: Sat Jul 07, 2012 7:55 am |
i thought they only go to 87, sorry my bad. shep wrote: zooky08 wrote: bit of confusion going on here. 88 is a nt 1.3 not a 1lt. it has a 1.3l engine. it willl have nt diffs with 3.9 1.3l size centers. nt 1l has a higher ratio and are smaller but not interchangable with nt 1.3 or wt 1.3 I know a fella that has a 1998 1.0 so a 88 is very possable most likely a maruti?
juzzys
 Posted: Sat Jul 07, 2012 8:06 am |
Is there any way of checking the ratio's?
zooky08
 Posted: Sat Jul 07, 2012 8:09 am |
jack the back up so wheels are off the ground. for 4.1 ratio is 4 turns of the drive shaft to one rotation of the wheel.
sideways
Joined: Fri Oct 29, 2010 1:53 pm Posts: 5935 Location: Northcliffe, W.A.
 Posted: Sat Jul 07, 2012 9:08 am |
juzzys wrote: Thanks mate! So if my 1 ltr is an 88 model and it has the wider tunnel etc, would It still be running the 1ltr axles? It's a late 88 Yep, the only 1l that had 1.3l sized diff centres was the WT Maruti (mid 90s onwards). All 1ls have a 4.11:1 diff ratios. The only way it would be different is if someone had fitted LJ50 (4.88:1), LJ80 (4.556:1) or Super Carry (5.12:1) diff gears, or swapped the 1l diffs out for 1.3l ones.
juzzys
 Posted: Sat Jul 07, 2012 11:20 am |
Thanks fella's i'll do the old spin the shaft and check..
2stroker
Joined: Sun Sep 07, 2008 11:30 pm Posts: 2689 Location: North Brisbane
 Posted: Sat Jul 07, 2012 2:04 pm |
Muzzy why are you asking, what are you chasing mate.
juzzys
 Posted: Sat Jul 07, 2012 2:39 pm |
I'm just looking at buying a set of 1.3 axles.. But the guy wants to sell them as a hole with the centres. And I always want to get the higher ratio for a better drive, as I'm running a 1.6..
Fatzook
 Posted: Sat Jul 07, 2012 2:50 pm |
zooky08 wrote: i thought they only go to 87, sorry my bad. shep wrote: zooky08 wrote: bit of confusion going on here. 88 is a nt 1.3 not a 1lt. it has a 1.3l engine. it willl have nt diffs with 3.9 1.3l size centers. nt 1l has a higher ratio and are smaller but not interchangable with nt 1.3 or wt 1.3 I know a fella that has a 1998 1.0 so a 88 is very possable most likely a maruti? Stop confusing the poor bloke.
Fatzook
 Posted: Sat Jul 07, 2012 2:51 pm |
juzzys wrote: I'm just looking at buying a set of 1.3 axles.. But the guy wants to sell them as a hole with the centres. And I always want to get the higher ratio for a better drive, as I'm running a 1.6.. buy WT sierra diffs, reset the spring perches to NT/1L possitions, and enjoy.
juzzys
 Posted: Sat Jul 07, 2012 3:00 pm |
Haha. Yeah I'm thinking of going down that path but I want to get a roadworthy first..
2stroker
 Posted: Sun Jul 08, 2012 11:19 am |
If it is just to get it going I have a set of 1 litre axles here you can have.
(Then you can buy some wide track diffs off me latter ha ha)
