It is currently Wed Aug 05, 2026 5:57 am
Post new topic Reply to topic  [ 48 posts ]  Go to page Previous  1, 2
Post Posted: Fri Aug 10, 2012 10:51 am
tanshi wrote:
oh and i do see the point in you being reluctant to encourage back yard diff modding.
Some of the shit I have seen over the years is terrifying.
Post Posted: Fri Aug 10, 2012 11:02 am
Well you are besties with shep.....nuff said :mrgreen:
Post Posted: Fri Aug 10, 2012 11:04 am
ball wrote:
I'm not trying to be a negative nancy for the hell of it. A diff is a pretty important part on a car that needs to be right, much like brakes.
I see the big reason we have so many rules and regs these days with modifying cars, is that somewhere along the lines, accidents have been caused by poor ideas, skills, materials etc and recommendations have come out to tighten up the regulations.
Rather than sleeving and butt welding tubes together, look at cutting to length and welding new ends on instead.
The bearing housings for common diffs like 9" and borg warners are reasonably cheap but I don't know about suzuki ones.
For the fronts, the big ball on the end will more than likely have a shoulder already pressed into the tube. If you carefully cut out the welds you should be able to re use the end.
This would go a long way to satisfying any engineering requirements. If you duplicate what was originally there, it looks better on paper. If you put a join in then it is an additional failure point.
All the welding would need to be done as per the Australian Standard too.
Totally agree with everything but we are talking an LJ for off road use here (I think) not some abortion with a V8 motor for the saturday night Pitt street drags.
Post Posted: Fri Aug 10, 2012 11:06 am
Nice attitude JB
Was just saying how things easily bend with weld.
Post Posted: Fri Aug 10, 2012 11:07 am
You don't think that off road use is somehow easier on vehicles do you?
Post Posted: Fri Aug 10, 2012 11:08 am
Makes shep's stuff look like world class formula 1 technology :wink:
Post Posted: Fri Aug 10, 2012 11:25 am
No but done at a much more sensible pace that does not tend to break people just cars.
Post Posted: Fri Aug 10, 2012 12:10 pm
in the jig above where they got alloy pucks made.
any one know if using bearings that fit the sizes needed would work instead?
Post Posted: Fri Aug 10, 2012 12:17 pm
303zuke wrote:
If a mod is reading this, can we pull across some of the most recent posts from the Chinasoong Thread, which weren't really relevant to the locker topic anyhow.
I don't have access to do it, I can just grab the last couple posts as quotes though?
Post Posted: Fri Aug 10, 2012 1:29 pm
I'd call that a checking guage, not a jig.
Post Posted: Fri Aug 10, 2012 1:50 pm
Jig or not a Jig, seems to me a crap load of people narrowing diffs using this method.
Post Posted: Fri Aug 10, 2012 8:06 pm
Whatever works. I just think they'd be more at home in this thread.
Post Posted: Fri Aug 10, 2012 9:04 pm
X2.
Buds customs use the same system for their custom housings. They seem to be moving quite a few of those, so it must work.
Post Posted: Fri Aug 10, 2012 10:08 pm
X2.
There was a good write up in Street Machine sometime in the last year or so about the custom diffs that Difillipo does.
They all go in the press to straighten after welding.
A company I once worked for made a jig for a doorslammer team. They used it for their top fuel bike chassis and I remember seeing a diff being built on it at one stage. It was 25mm or 30 mm plate and once all the fixtures were in place you could completely mess up the sequence and it would still come out straight. These diffs were quite short end to end though.
Post Posted: Sun Aug 12, 2012 9:25 am
the last page of this thread he swaps his centre to the other side. you could use the same idea i guess.
http://www.pirate4x4.com/forum/showthre ... 218&page=8
Post Posted: Sun Aug 12, 2012 9:49 am
that was in the June 2010 edition if I remember correctly. :?
Post Posted: Sun Aug 12, 2012 10:59 am
I will have a look for that issue when I get home tonight. :wink:
Post Posted: Sun Aug 12, 2012 11:50 am
i found my copy, was the june edition... don't have a scanner at home but here are some pics of the jig.
even with a jig like that it still ends up having to be straightened.
Users browsing this forum: Google [Bot], Google Adsense [Bot] and 1014 guests
