It is currently Thu Jul 23, 2026 9:43 am
Post Posted: Tue May 19, 2009 12:20 am
hi just looking at at geting an mk1 gti swift ( hole runing car)
also i have a 2.5" body lift in my sierra
what parts do i need to buy to fit it to my sierra
- dissy ( can i get away with useing the stock gti dissy or do i have to get the angle drive kit
- wiring ( is there any think special that i need to buy
-fuel ( can i get an inline pump insted of an in tank one
-clutch ( can i use the stock sierra one
-cooling ( what rad hoses do i need to get or buy - aleardy using an thermo fan on the sierra
- exhaust ( what manifold will fit or is it an custom jobby
-engine mounts ( what ones do i need to get
-any think i have missed
is there an link to an guied to what ineed to mod to fit it in my sierra
Post Posted: Tue May 19, 2009 11:54 am
Have a read through Chinny's build
http://auszookers.com/index.php?name=Fo ... pic&t=3180
Post Posted: Tue May 19, 2009 12:06 pm
As per Scrawn's post, Chinny had a good result using a Mazda dizzy cap and rotor.
Just make sure you have the loom with the engine. Have you got a copy of the GTi FSM?
Yep, you can do that. I'd highly recommend a surge tank with a 2nd pump though.
Yes
Custom. Get some Sierra extractors and a GTi flange. Cut the flange off the Sierra extractors and have them welded to the GTi flange. Fatzook on this forum should be able to hook you up with a GTi flange.
Stock Sierra mounts will fit.
As Scrawn said read Chinny's build.
Post Posted: Tue May 19, 2009 1:40 pm
where can i get the gti fsm from ( i also have the compleat runing car so i will have all the wiring)
Post Posted: Tue May 19, 2009 1:55 pm
i would say suzukiinfo.com but it's down at the moment. Redlinegti forums are you next best bet, you could also try teamswift.net.
lesspostingmorewheeling
Post Posted: Tue May 19, 2009 9:15 pm
you have to use an angle drive on a mk1 motor because the mazda dizzy cap won't fit the mk1 dizzy
Post Posted: Wed May 20, 2009 2:37 am
can i give the firewall an little love tap with a big hammer of that wont work with the mk1
Post Posted: Wed May 20, 2009 2:42 am
it would have to be a big love tap
when using a mazda dizzy cap on a mk3 motor you have to take the motor out to get the dizzy cap off because there is only a couple mm clearance
you'd need to cut a hole rather than massage it with a hammer but thats way too dodgy angle drive is the best way to go
Post Posted: Wed May 20, 2009 2:44 am
can u use na mk2/3 dissy on the mk1 motor or that wont work eather
dame more money this is going to cost more then i have atm
Post Posted: Wed May 20, 2009 2:50 am
at least using the g13b for a conversion you won't need an adaptor kit like you would for a g16 the angle drive is the only major expense other than the motor
Post Posted: Wed May 20, 2009 2:52 am
yer that ture and the exhuast is the other big expence getign it cut and rewelded to fir the g13b
Post Posted: Wed May 20, 2009 2:58 am
it shouldn't cost that much as long as you have some sierra extractors and the gti exhaust flange
it would be piss easy to do yourself if you can weld
Post Posted: Wed May 20, 2009 3:03 am
dont have the extractors and havent ever done any welding do will have to get some one else to do it ( can u sue the stock sierra header with the gti flange or will it be to restrictive)
Post Posted: Wed May 20, 2009 3:10 am
to be honest i can't even remember what a stock sierra manifold looks like
if you were gonna stuff around changing flanges you'd get a set of extractors any exhaust place should be able to weld the flange on
Post Posted: Wed May 20, 2009 3:15 am
ok thx i will have to look in to it and maby scrap the hole idear ( it is all addign up to be to much atm)
Users browsing this forum: Google [Bot] and 56 guests
